Leaky Rear Brake Caliper/Piston
3 replies to this topic
  • slowxr
Posted September 16, 2006 - 09:21 AM
My rear caliper appears to be leaking. I'm noticing it around the brake piston.
1)Do I replace the dust seal and seal or is there a simple trick I can try?
FYI, not sure if it was a coincidence but I road 150 miles with my wheel/axle not lined up. I noticed this when I got home. Just a coincidence that my piston started leaking?
Any idea's?
  • slowxr
Posted September 16, 2006 - 12:02 PM
Any chance the misaligned rotor generated excessive heat which is causing the leak?
I'm hoping if I clean up the piston and realign the tire, the problem with remedy itself.
What's the likelihood of that?
  • slowxr
Posted September 18, 2006 - 07:34 AM
I cleaned up the caliper and can see a seal pushing out the side of the piston.
Has anyone replaced these seals before. It seems pretty straight forward in the manual. Any thing to be aware of or special tools necessary?
Thanks
  • slowxr
Posted September 28, 2006 - 01:57 PM
For those that are interested.
I replaced oil seal, dust seal and piston.
The manual suggests bleeding complete system of brake fluid. I didn't.
I removed caliper, pulled the piston out by hand, cleaned the inside of caliper with brake cleaner and reassembled with new parts.
The seals looked good to the eye but I did find a metal shaving in the caliper. Maybe that's what caused the leak.
  • Hot  35 replies
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
  • 22 replies
