07 Xr650l Pro Taper Cr Hi Bend Info
10 replies to this topic
  • pgiinc
Posted September 13, 2006 - 11:16 AM
I want to put these bars on my bike does anyone know if they will bolt right on stock tree or do I need an adaptor and if so please give me a link or part number
thanks
  • pigryder
Posted September 13, 2006 - 01:41 PM
Are They The Fat Bars Or Se???
  • pgiinc
Posted September 13, 2006 - 02:44 PM
Se Or Fat Were Are The Rise Adaptoers That I Can Use The Stock Tree
  • justicedone
Posted September 13, 2006 - 03:43 PM
just go to a local dealer, they can help
  • lhark
Posted September 13, 2006 - 04:07 PM
Moose makes them for the fat bars. Check with your Parts Unlimited dealer, they should be in the catalog.
  • HappyCurmudgeon
Posted September 14, 2006 - 03:03 AM
Bottom left of this page TT Store
Part Number T-4090. This is what I have on my L with 1-1/8" Renthal Twinwall CR High bends. Raises them up just a touch as well which i like also.
  • pgiinc
Posted September 14, 2006 - 09:00 AM
what do you think about this setup on ebay ?
http://cgi.ebay.com/...026985323QQrdZ1
and the Renthal twinwall rc hi 922 bars here?
http://shop.thumpert...p?p2=&s=2&p=528
I am 6' I just want somthing more like the CRF450X is setup what do you think
  • SpringChicken
Posted September 14, 2006 - 09:11 AM
First off, I think the pro tapers are much better than the renthals. Second, where are you going to buy your bars? Just go down to your local shop. If they have the bars, they'll have the adapters. The protaper brand adaptors are only $40. You are totally over thinking this. justicedone has given you the best responce yet. After you go to your local shop and get all of this done, you'll think to yourself, "why didn't I just do this in the first place?" C'mon, get off that computer chair and go to cycle gear or something! I believe in you!!
  • huffster
Posted September 14, 2006 - 09:48 AM
thanks
If you get the 7/8" SE bars, they are a direct fit and will need nothing, other than a few minutes to install.
If you go with oversized Pro-Tapers, then you would need an adpater kit.
If you bike has solid mounted bars stock, then you need # 02-4899
If your bike has rubber-mounted bars stock, then you need # 02-4898.
These are the Pro-Taper part #'s available through Tucker Rocky at your favorite dealer or through the Thumpertalk store !! :thumbsup:
  • Edward282
Posted September 14, 2006 - 12:42 PM
ok I did get up out of the chair and when to local shop and they did not have dick any came back and orded these
Code Item Qty Price Total
TR_027915 CONTOUR CR HIGH SIL PT
1 $62.99 $62.99
TR_024899 PROTAPER UNIV MNT KT NO PAD
1 $35.99 $35.99
TR_024847 PROTAPER 1/2 WAFL SFT BK
1 $8.99 $8.99
TR_176130 GRIP GLUE
1 $1.76 $1.76
  • pgiinc
Posted September 14, 2006 - 06:40 PM
thanks huffster
I got the Protaper CR HI contours and the Protaper adaptor grips and glue
Honda XR650L 2016
  • 0 reviews
  • 9 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
