Need help finding top dead center
13 replies to this topic
  • XR 650
Posted September 11, 2006 - 01:21 PM
When I look at the flywheel I see three marks on the flywheel turn by :
I
I F
I T (T is horizontal, not vertical)
The clearance are not right when I adjusted at I T. My CD Manual shows the T vertical & seems simple to line up. I'm adjusting the intake .004 & exhaust .005. Can someone explain what I"m doing wrong.
Thanks
  • Xr650rhonda
Posted September 11, 2006 - 01:52 PM
When you look inside the spark plug hole is the piston at the top of the cylinder when the pointer is on the "T" ?
  • captb
Posted September 11, 2006 - 01:57 PM
It needs to be on T on compression stroke and if you rotate it backwards even the slightest it decompresses (auto decompressor) and adjustments will be wrong the decomp exhaust valve will start to open. Put your finger over the spark plug hole and rotate it you will feel when you are on compression stroke then go slow till tou are on the T if you reverse at all you need to start over compession is every other crankshaft rotation.
  • surfnride
Posted September 11, 2006 - 02:00 PM
try spinning the crank around 2 or 3 times. then line up the T with the notch in the sidecase.
  • XR4DEZ
Posted September 11, 2006 - 03:01 PM
It's .006 for the intake and .008 on the exhaust for the 650r.
  • XR 650
Posted September 11, 2006 - 04:15 PM
Thanks!
I got it finally. (I guess it was kicking back and throwing it off).
  • spotsboss
Posted September 12, 2006 - 07:26 AM
XR,
To be sure, try this: www.advrider.com/forums/showthread.php?t=94861
  • Max Power
Posted September 12, 2006 - 07:01 PM
How do you know it's an "R"?
  • XR4DEZ
Posted September 12, 2006 - 07:19 PM
You're right, I assumed.
  • XR 650
Posted September 13, 2006 - 01:02 AM
It's a L. Forgot to put it in the title.
  • ponq
Posted September 13, 2006 - 08:57 AM
Another example of why there should be a separate L and R forum.
  • underwatersimon
Posted September 13, 2006 - 04:31 PM
This is exactly right, I thought I was stupid the first time I tried this as well.
  • icedfusion
Posted September 14, 2006 - 04:35 AM
Excellent Link - printed off and will keep a copy of that gem of advice.
Thanks
ice.
  • XR650L_Dave
Posted September 14, 2006 - 07:36 AM
No, its an example of why it would be convenient for you if there were seperate forums.
D
  • 3 replies
  • Hot  186 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
