I have an 02 WR 250 wtih a Grarly pipe, v-force, and a Keihn PWK carb. I am fairly happy with the stock gearing but I am less then pleased with the transmissoins ability to shift from 2nd to 1st without stopping for neatral so I think I need to just eliminate the need for first gear on a hill climb.
The stock chain is not stretched at all. Does anyone know how many teeth up I can go without having to replace the chain? If I do have to replace it what chain and lenght do I need? Am I correct in assuming there are no cross over rear sprockets for a Husky?
sprockets for WR250
Started by
NWetRider
, Sep 10 2006 09:03 PM
8 replies to this topic
Posted 11 September 2006 - 04:04 AM
My '00 had 13/48 stock and I was able to fit a 51 with stock chain running the axle way up. I run a 13/52 now, but can't tell you how many links. Many rear sprockets availible from different suppliers. I always used JT steel, but last two used Huskys I bought had Renthal aluminum and they hold up really well in gruesome Northeast mud.
Posted 11 September 2006 - 05:24 AM
Not that they are any easier to find, but Gas Gas and Husky rear sprockets are the same.
Posted 11 September 2006 - 08:26 AM
I was thinking of using a 50 so I guess it should fit. A 52 must have made a major change!
Did moving the axel way forward change the handling any? I am concerned that the shorter effective swingarm length might make it harder to keep the front end down while climbing. Maybe that isn't enough of a change to worry about?
Posted 11 September 2006 - 03:30 PM
I couldnt imagine running a 50T on my WR250.
The top speed is not great already and I find the bike really "jumpy" in the tight stuff with the stock gearing. I am tempted to put a 47T on mine to try to mellow it out a bit.
Posted 11 September 2006 - 04:35 PM
It seems people with the newer WR's are gearing up instead of down. I guess they must have a lot more hit and pull then the older ones.
Posted 11 September 2006 - 04:55 PM
Am I correct in assuming there are no cross over rear sprockets for a Husky?[/QUOTE]
JT makes front and rear sprockets for 2 and 4 stroke huskys. any dealer that does parts unlimited should be able to get them. i will get you the part #'s if you cant find any.
Posted 12 September 2006 - 05:35 PM
Halls has them for $30.00
halls-cycles.com
I run a 51 on my 02 - I think a may go for the Ironman next time.
- Craig
02 WR250
05 TE450
halls-cycles.com
- Craig
02 WR250
05 TE450
Posted 12 September 2006 - 07:09 PM
thanks everyone, I ended up ordering a 50 tooth JT from bikebandit. I saw the deal at Halls but my choices would have been a 49 or 52.
