XRR Swing arm nut problem
3 replies to this topic
  • Miguel159
Posted September 10, 2006 - 03:12 PM
I just installed Devol frame guards on my XRR. I had to use an impact wrench to get the left side swing arm nut off. Holy frig was it tight. I noticed that when tight, it had four full threads showing exposed on the shaft. After I installed the devol aluminum guard and torqued the nut back on there is only one thread showing. The service manual stated 80 ft/lb for the nut. I realize the aluminum guard under the nut takes up some space but it can't be any more than 2mm thick. Does 80 ft/lb seem right after having to use an impact gun to take it off? I worried the swing arm won't be torqued properly on the bearings etc. Am I being paranoid :thumbsup:
  • Max Power
Posted September 10, 2006 - 06:29 PM
Yes, 80 ft/lbs is right. The swing arm bearings require a special tool to adjust.
Did you pull the swing arm bolt out and grease it?
  • Miguel159
Posted September 11, 2006 - 09:43 AM
thanks for the reply Max. No I didn't grease the swing arm bolt. I'd like to. Do I need the wheel off and the bike on a work stand. Can it be done easily and do you need a swing arm tool for the castled nut on the right side?
  • Max Power
Posted September 11, 2006 - 06:11 PM
Not the end of the world. With the left side nut off, the bolt can be removed. Mine needed some help (brass punch and hammer).
When I did it, the bike was on a stand, tire and shock was removed.
  • Hot  29 replies
  • 4 replies
  • 17 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
