Question about TPS...
5 replies to this topic
  • creeker
Posted September 10, 2006 - 10:59 AM
According to my service manual you are to NOT remove the TPS unless you are replacing it. It says if this is removed you will experience performance loss... is this correct???
  • clark4131
Posted September 10, 2006 - 11:56 AM
DO NOT remove it, bad ju-ju. However, you can unplug it to remove its effect, or you can adjust it if the voltage is incorrect, per the manual...SC
  • creeker
Posted September 10, 2006 - 04:43 PM
I didn't remove it, but was curious as to what would happen if you did...
  • trailordune
Posted September 11, 2006 - 11:00 AM
nothing happened on my 04. runs great, even better after it is adjusted correctly. :thumbsup:
  • creeker
Posted September 11, 2006 - 11:10 AM
Is it difficult to adjust?
  • A-ron
Posted September 11, 2006 - 12:03 PM
Very you have a multimeter? Grab one and your manual and you're set. Read here for more help.
