front fork settings for WR450 - 2005
5 replies to this topic
  • Murray Dorward
Posted September 09, 2006 - 12:36 AM
I need the standard fork settings for a WR450 2005 as both forks have been set up differantly.
Muz :thumbsup:
  • OneToGo
Posted September 09, 2006 - 06:11 AM
Try the pdf manual available for free download:
I have a 06 so the settings are different.
Make sure you check for the SA model - I know for the 06 they were a different setup from those in AUS/US/EURO which believe it or not, all have slightly different spring and damping rates..
PS. I did not check to see if the PDF manual has your model, just assumed it did like the 06 manual does.
  • Murray Dorward
Posted September 09, 2006 - 09:40 AM
thanks for advive but I went and dowloaded the workshop manual and all they say is "Turn dampining adjuster to the original position". What is the original position ??????? :applause: :thumbsup:
  • gilbert44a
Posted September 09, 2006 - 10:56 AM
Rebound: 10 clicks out
12 clicks out (for Europe)
14 clicks out (for AUS,NZ and ZA)
Compression: 13 clicks out
Standard oil level:128 mm
130mm (for Europe,AUS,NZ and ZA)
  • Murray Dorward
Posted September 10, 2006 - 09:13 AM
thanks for your help
  • Just_a_trail_rider
Posted September 10, 2006 - 07:46 PM
suspension settings are custom to the rider. You will have to find the ones that work for you.
