Slide in carb in backwards??
8 replies to this topic
  • MountainMax
Posted September 06, 2006 - 07:46 AM
Hey guys, a while back (cant find it in search now) i told you guys that my bike would backfire on decel and i have a 50 pilot jet and 3 turns out on my mixture screw. Someone said that possibly part of my slide was in backwards. I just got back of holidays and removed the carb and took pics front and back, can someone tell me is this right or is there that condition on my bike, I need to know asap before i put it back on. Thanks guys.
Attached are a couple of pics.
  • yamageezer
Posted September 06, 2006 - 07:57 AM
I just looked at mine and it's the same as yours. Have you looked for and exhaust leak yet? Also did your bike come with AIS?
  • creeker
Posted September 06, 2006 - 08:40 AM
Mine looks just like yours, except my slide won't go all the way down now for some reason...
  • Jackazz
Posted September 06, 2006 - 08:56 AM
looks good to me...
http://parts.yamaha-...ifx?d=51817,2,0
  • MountainMax
Posted September 06, 2006 - 09:10 AM
Ok, i guess I will shove it back in again. still have to work out why she's backfiring though on decel with the mixture screw out any less then 3 turns, upped from 48 to 50 pilot jet and it's still exactly the same thing, only now i can start it when cold without using the choke so I know I should be too rich there. Maybe there is something else i can try..
  • ferguscawley
Posted September 06, 2006 - 10:12 AM
AIS system I would think. Bypass or disconnect it. 50 pilot is very big, especially 3 turns out.
  • MountainMax
Posted September 06, 2006 - 01:19 PM
Ok how do i disable it? I have removed the smog pump thing already, is this the air circuit on the side of the carb? BTW i have my bike done all to yz specs, exhauset camshaft, timing, exhaust...... can i go back to 48 pilot then or what other changes do i need to make after modding the ais?
  • Guest_Dean58_*
Posted September 06, 2006 - 11:52 PM
Look at this thread for info.
http://www.thumperfa...ee_mods.htm#WRF
  • MountainMax
Posted September 07, 2006 - 09:55 AM
this ais is long gone, i bought the ais removal kit from yamaha first when i bought the bike, i though you meant the air cut valve, maybe i need to mod this so it would be more like the Yz 450 as everything else is.
