XR650L horn won't work when idling?
8 replies to this topic
  • twerner
Posted September 05, 2006 - 06:19 PM
Horn and blinkers will only work at high rpms.
What could be the cause? Stator? Regulator?
Just installed a new battery.
  • LotsOfBikes
Posted September 10, 2006 - 10:42 PM
More info will help.
Hook a volt meter up to your battery with the bike running. See if there is a voltage difference at the battery:
1. Not running, ignition off
2. Ignition on, not running
3. Engine idling
4. Engine revved up
You might have something loose or just not connecting right.
  • reduceus
Posted December 07, 2008 - 03:31 AM
I have a brand new XR650L and it has a similar problem - at low engine revs the lights, indicators are ok but the horn refuses to sound. I have to give it a handful of revs to make it work - should this happen on a new machineI
  • wattner
Posted December 07, 2008 - 06:38 AM
that sounds like a grounding problem!!!
  • martinfan30
Posted December 07, 2008 - 08:04 AM
If it's new, take it back to the dealer!
  • reduceus
Posted December 08, 2008 - 01:27 AM
Would love to be able to take it back to the dealer, but it would be a very wet journey - He is in Tampa, Florida - I am in The Gambia, West Africa. Could you suggest a suitable route please?
Have tried the earth(ground - all ok). The horn (crappy as it is) works fime when the revs are up but stops working when you let the throttle go - odd!!!
  • Kenzo
Posted December 08, 2008 - 06:23 AM
sounds like a simple battery problem...sometimes the obvious gets overlooked :smirk:
check, clean & tighten ur battery connections...can't remember if the stock battery is sealed or not but if it's unsealed check the fluid levels...
if that does not correct the problem test the battery...it may be failing or faulty.
:thumbsup:
  • scalejockey
Posted December 08, 2008 - 07:32 AM
On the back of the horn will be a small screw with and a lock down nut. Try and adjust it in and out,that sometimes will bring a horn back to life.
  • reduceus
Posted December 15, 2008 - 09:35 AM
Thanks for the advice, have finally had time to play - the problem was the horn, it's crap. Why put such a puny thing on a BRP, may save Honda money but it looses brownie points on quality.
Have just ordered a Stebel Magnum, 136db - locals should hear that.....
http://www.nippynorm...ts.asp?dept=259
  • 3 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
