06 YZ450f Scott's oil filter question? (pics)
11 replies to this topic
  • WFOracer
Posted September 04, 2006 - 08:20 PM
Check out these pictures of my scott' stainless oil filter. That little rubber gasket on the top of it is starting to fall apart. It seems like everytime I take it out, there are more chunks missing from it. Anyone else run into this? I am running Bel-Ray Thumper oil. Sorry, my camera wouldn't (can't) focus that close, so they are a little blurry.
Posted September 04, 2006 - 10:15 PM
I haven't had any such problems running a Scotts, but you should contact customer support using the link on This Page for a replacement, and find out why it could be happening.
  • SureBlue
Posted September 04, 2006 - 10:25 PM
With what and how do you clean it?
  • WFOracer
Posted September 05, 2006 - 04:19 AM
Thanks grey, I'll send them an email.
I use bel-ray contact cleaner to spray it out.
  • Ga426owner
Posted September 05, 2006 - 05:22 AM
You can replace the rubber top - Ace Hardware has the exact replcement -
glue on with 3m or other adhesive.
That one looks like it is falling apart - mine has not done this but does regularly unglue itself.
  • WFOracer
Posted September 05, 2006 - 06:29 AM
Really? Glue? Wouldn't that just end up disolved in your engine oil...or disolving during cleaning?
  • Vibeguy
Posted September 05, 2006 - 08:40 AM
Any swelling and/or softening of an elastomer is typicaly caused by chemical attack. Some electrical contact or carb cleaners can raise hell with elastomers, especially if the part is left to soak in it.
The Bel Ray oil you use is not the problem.
  • WFOracer
Posted September 05, 2006 - 09:11 AM
What kind of cleaner is recommended for the Scott's filter?
Posted September 05, 2006 - 10:21 AM
I wouldn't use contact cleaner. That could be the problem. Use carb cleaner, such as Berryman's B12, instead.
David,
Thanks for the tip. Where within the store do you find the seals at Ace? My oldest one is pretty squashed.
  • Ga450owner
Posted September 05, 2006 - 10:49 AM
David,
I go to the area where all the different types of specialty screws etc.. are....corks, rubber stoppers....(I use these for exhaust stoppers)
Posted September 05, 2006 - 11:44 AM
Thanks,
"Newbie" :thumbsup:
  • SureBlue
Posted September 05, 2006 - 03:21 PM
:applause:
:applause: :applause:
One thing I don't get, 450ownwer's join date and post count, pls explain, David. :thumbsup:
  • Hot  38 replies
  • Hot  50 replies
  • Hot  47 replies
