2001 yz426 problem
30 replies to this topic
Posted September 10, 2006 - 07:19 AM
#21
An exhaust leak can cause the popping, but none of the performance issues you mention.
  • GONE1445
Posted September 10, 2006 - 02:50 PM
#22
ok thanx
  • Yama4Stroker
Posted September 11, 2006 - 12:56 PM
#23
Could be wrong here, but thought I would throw this out as well. The 400's had a problem with the slide plate in the carb cracking, and eventually breaking off into the motor. But a crack in slide would also create a lean condition. I believe this was fixed for the 426's, just another option.
  • GONE1445
Posted September 16, 2006 - 07:51 PM
#24
thanks for the info but I had the carb apart and checked everything over with a fine tooth comb and nothing little dirty but sprayed it all out with carb cleaner
I took the carb apart, new plug, new springs(Not relavent to motor but throwin it out there), ready filter(questioning that now gotta check tomorrow), and cables are still not here
and I finally got it back together and it still does the same thing when choke is on it idles really high and pops alot and I havent run it enough to really get it warm since it first did this
could it be the valves?? I am gonna try and check them tomorrow
  • SureBlue
Posted September 16, 2006 - 10:44 PM
#25
It sounds like you have the throttle slide upside down, but you said you haven't touched anything since you bought the bike :thumbsup:
  • GONE1445
Posted September 17, 2006 - 01:25 PM
#26
yea
and how should the throttle slide be
that half moon shape curve like cut in the one end goes on the bottom right??
I did take the slide out but I didn't take the needle out or anything so I am 99% sure its in there right side up
gonna take carb back off and check everything once again maybe I missed somethin
and how do you adjust the throttle cable's ?? like how much slack should there be??
Posted September 17, 2006 - 05:32 PM
#27
Yes, and facing to the air filter. The spring plate on the slide faces the engine. It can also be inverted inadvertantly. The small hole belongs in the bottom.
1-3 mm if I remember right. Try it with the bars turned in several positions.
  • GONE1445
Posted September 17, 2006 - 06:23 PM
#28
is the spring plate that plate that sits on the front of the slide and if its upside down will it cause any of my symtoms
Posted September 18, 2006 - 07:57 AM
#29
Inverted spring plates cause the bike to run very rich at and just off idle, up to about 1/4 throttle. Doesn't sound like your problem.
  • GONE1445
Posted September 18, 2006 - 06:48 PM
#30
well I think I fixed it
I took the jets out and found a little piece of rubber(looks like part of a balloon) in there so I got that out and put it back together now she starts fine and idles good on choke don't have the room to warm it up at my grandpa's so I'll test that soon
it still pop's tho I think the exhaust gasket is worn out will that cause it??
Posted September 18, 2006 - 08:39 PM
#31
It could if it's loose and leaking air. 1-3 pops on decel means the pilot jet and screw are just right, IMO.
  • 3 replies
  • 0 replies
  • Hot  28 replies
