Noise Reduction Strategies for WR450
12 replies to this topic
  • Cairn
Posted September 03, 2006 - 01:07 PM
Am currently running a stock muffler with the baffle removed on my '05 WR450 and would like to quiet down the exhaust. Is the Promoto Billet WRF insert a good solution? Are there other products or strategies? Am not concerned about giving up a little power and want to reduce the noise by 5 or more db.
Thanks.
Cairn
  • BIGBLUEKNIGHT
Posted September 03, 2006 - 01:25 PM
fmf q2
  • Cairn
Posted September 03, 2006 - 03:25 PM
Thanks BigBlueKnight...a great solution...anyone using the PMB muffler insert or other insert to the stock muffler???
Cairn
  • tony1970
Posted September 03, 2006 - 04:09 PM
Love my PMB. Quiet and gives you a power increase over stock.
  • TuningFork426
Posted September 03, 2006 - 05:20 PM
you could put the baffle back in
  • Cairn
Posted September 03, 2006 - 07:15 PM
Thanks for the feedback Tony1970 & TuningFork426. Short of knowing the facts, I assume that the PMB insert and the stock baffle serve the same function but the PMB insert provides better flow/performance at about the same noise level. Anyone know if this is a good assumption.
Appreciate the responses.
Cairn
  • tony1970
Posted September 03, 2006 - 08:52 PM
Cairn
The PMB insert replaces the stock baffle, and provides better flow with only a small increase in sound. They state that there is a 5hp increase with it. Quiet Is Cool also makes a similar baffle to the PMB. If you do not want to spend the money on a new slip on pipe I would go with the PMB set up and spend your money on suspension work.
  • Cairn
Posted September 04, 2006 - 04:37 AM
Got it. Thanks, Tony.
  • MNMike
Posted September 04, 2006 - 05:12 AM
The GYT-R baffle is only ~$40 and will get you to 96db.
  • 2tall2tall
Posted September 04, 2006 - 08:07 AM
The quiet is cool insert works really good and is 94DB.
www.quietiscool.com
  • jim-in-so-ore
Posted September 04, 2006 - 08:16 AM
I have the PMB insert on the 05 muffler that I'm running on my 03 WR. It works so much better than the stock pea shooter and only increases the sound a small amount. It was money well spent.
Jim
  • gdm
Posted September 04, 2006 - 09:46 AM
I am running the PMB insert and just rode the Colorado 500 where they have strict noise regulations. My bike tested at 90 decibels and it runs great! I highly recommend the PMB insert.
  • Cairn
Posted September 04, 2006 - 11:24 AM
Really appreciate the feedback. Thanks! :thumbsup:
Cairn
