White brothers help please. XR650L
5 replies to this topic
  • ajones
Posted September 02, 2006 - 06:50 AM
Hey Gang, I purchase a new White Bro. e2 (part number 05-603) off eBay. It is listed as XR600 years '85-'87 & '91-'00 and XR650L '93-'98.
My bike is a 1993 XR650L.
The mount near the slip on is about 2 inch off and the top mount or fender mount is about 8 inch off.
What am I missing?..... Is this the wrong pipe? :thumbsup:
Thank you for your help.
AJ
  • MindBlower
Posted September 02, 2006 - 07:27 AM
gotta be the wrong one. It happens.
  • ajones
Posted September 02, 2006 - 11:00 AM
I may have and exhaust for sale for a XR600R.
FYI~
www.BTOsports.com has different part numbers for the two bikes. I've been shopping eBay for sometime and there several listing having this pipe fitting both bikes.
Model: XR600R_91-01_(05-603) What I have.
Model: XR650L_93-05_(05-618) What I need.
Bummer.
AJ
  • ajones
Posted September 12, 2006 - 04:04 PM
Follow Up
I hope someone can learn from my mistakes. I bought the XRL White Brother pipe Model: XR650L_93-05_(05-618). I'm 99% sure (05-603) would have work after all.
The Botton mount was two inches off because there is a wire mash wrap gasket for the stock pipe. My gasket was worn smooth an looked like part of the header pipe. When I sliped on the new pipe I notice it was two inches off. :thumbsup: I removed the gasket with a screw driver an snips. the everything lined up.
The differents in the two stock numbers is a bolt that is 1.5 or 2.0 inches longer an a spacer. You remove the bolt that hold on the turn signal replace it with the longer bolt and spacer. That is the difference.
I'm not the sharpest. :applause: I hope this keep you from buying two pipes.
AJ :applause:
  • lhark
Posted September 13, 2006 - 04:05 PM
The Yosh can I bought for my XR650L, was listed for the XR600R. It fit fine, and works great. This one was oval comp type, with a ring band that moved to the right spot, with no sweat. It's held up well through 4 summers. Maybe you could forego the stock mount on the White Bros, and use the clamp ring style. A good sheet metal shop should be able to roll you up one...
  • TexasXR650L
Posted October 02, 2006 - 11:27 AM
Follow Up
The differents in the two stock numbers is a bolt that is 1.5 or 2.0 inches longer an a spacer. You remove the bolt that hold on the turn signal replace it with the longer bolt and spacer. That is the difference. :lame:
I'm not the sharpest. :bonk: I hope this keep you from buying two pipes.
AJ :p
I have a 05' xr650l and put the wb e2 exhaust on it. part # 05-603 and it fit perfectly, loud as hell and performance has gone waaaay up. love it. i didnt however re-jet it. saw on a web site that i didnt have to. hope that true, think it was off of the wb site itself. let me know about jetting with this exhaust.
  • Hot  35 replies
  • 9 replies
  • 4 replies
Honda XR650L 2016
  • 0 reviews
