Can a YZ450F Tank and Shrouds fit on a WR450F ?
2 replies to this topic
  • jecsr
Posted September 01, 2006 - 05:58 PM
Sorry if this has been discussed before. I tried the search engine. However, it is down. Thanks for any replies.
  • bmeador
Posted September 01, 2006 - 07:03 PM
Yes it will work on 03-06 models.
  • PBDBLUE
Posted September 01, 2006 - 07:55 PM
Works nicely but you will need a YZ seat as well. Also the YZ seat pan will need to be relieved to allow clearance for the battery and WR mount tabs and the YZ seat "hook" at the front needs to be removed since the WR frame does not provide for it. In the end the seat will be held on by the two bolts at the rear and the button on the tank. I've run this setup quite a bit and the seat has yet to come loose.
