Baja Designs Switch.
6 replies to this topic
  • BluezookS
Posted August 31, 2006 - 08:48 AM
I found a problem with my Baja Designs kit switch. I had a crash :applause: on my XR650R and when I crawled back to the bike and got it upright the ON/OFF light switch was smashed and the actuator was missing. The switch worked fine up until that point.
The battery pack is weak so I couldn't tell if it was on by looking at the taillight.
I kicked a bunch of times with the compression release pulled in and the throttle wide open. I got a backfire but it never fired up. :applause:
I was able to get my buddy to come pick me up and get home.
So I bought the XRR thinking it kicks pretty easy, almost starts by accident. I don't need an electric start. Then the crash, on/off messed up, am I kicking for nothing, man an electric start would be nice in this situation.
Plans:
I am definately going to label the wires so I can rig the wiring to start incase the switch is messed up. This is the purpose of the post to suggest this for others.
Rig a seperate on/off switch for anti-theft and ease of start after a crash.
Ride slower when by myself. :thumbsup:
  • snaggleXR650
Posted August 31, 2006 - 09:04 AM
The instructions with the DSK show which two wires to connect/disconnect to bypass the handlebar kill switch. One is black with a white stripe, the other is yellow or green or something...
  • moleculo
Posted August 31, 2006 - 09:14 AM
I found a problem with my Baja Designs kit switch. I had a crash :thumbsup: on my XR650R and when I crawled back to the bike and got it upright the ON/OFF light switch was smashed and the actuator was missing. The switch worked fine up until that point.
Sounds more like the Baja Designs kit switch found a problem with you!
  • InternalCombustion
Posted August 31, 2006 - 09:40 AM
Sorry to hear about the train wreck. Bummer, but at least no significant road-rash.
Re the BD switch, if you do not already have it, here is the info / diagram for the current switch.
Hope this helps!
Black w/ white stripe – Kill wire. Attach to stock kill wire that the stock kill button unplugs from.
Blue w/ white stripe – Kill wire ground. Attach to chassis ground (or factory wire that goes to chassis ground.)
Blue – Power in. Attach to fused DC power.
Red – Accessory power out. Hot in either of the two upper switch positions. Use to power taillight, turn signals, & horn.
Light Green – Power to low beam.
Yellow – Power to high beam.
Brown – Power to left turn signals.
Dark Green – Power to right turn signals.
Orange – Power to turn signal switch from flasher relay.
Pink – Horn wire. Attach to one side of horn.
Black – Ground for horn and high beam indicator. Attach to DC ground (not always chassis.)
Update: the above color codes are for BD's current-stock control switch. This is the design that has a kill-switch in the shape of a little mini-lever, vs the older design, which has a square kill-button. I cannot vouch that these codes are correct for the older design.
  • hypersthenos
Posted August 31, 2006 - 09:42 AM
Yep, just disconnect the 2 wires that go to the original wiring harness that used to go to your stock kill switch & you're good to go.
Posted August 31, 2006 - 10:00 AM
Holy crap, Batman! You musta REALLY had a train-wreck, in order to bust up the handlebar switch!!
:thumbsup:
  • BluezookS
Posted August 31, 2006 - 10:18 AM
The bike already had the BD kit on it when I bought it. It was working great and I saw no need to play with the wires. Now I need to know how to hot wire it.
I was having a good ride on this gravel road. I had just changed my pilot jet and the BRP was running crisp and fine. Retuning home there was a water puddle spanning the road with a dry spot to the left. I cleared that without getting wet, next was a wooden bridge thing. It is flush with the road and a small stream runs under it. It is made of 4x4s and is about 10'x 20'. I must have been on the gas and it was slick the bike went sideways on the wood, got traction on the gravel and launched me.
All I know is I was looking down the road the whole time. I had the same visual but was not on the bike anymore. It was like it the BRP was snatched from underneath me. :thumbsup:
