HELP!!!! XR wont run
4 replies to this topic
  • richgiffen
Posted August 31, 2006 - 07:34 AM
I bought a 1994 XR650L a week or two ago. The bike runs fine but was neglected for years and now needs simple work. Well the last day or two I was riding it and while riding it starting jerking and puttering kinda violently. Similar to when you are in way to low of a gear, or running out of gas. The only problem is that it was neither of those. It has plently of gas, and I know how to ride so it was in gear properly. Now the bike wont start. It cranks and cranks but no start. What could it be???? Spark plug???
  • gofastgofast
Posted August 31, 2006 - 08:19 AM
Sounds like a fuel supply problem! Which is likely as you said the bike was neglected (a dirty shame for such a good bike) The first thing I would do is pull the carby off and give it a good clean out, including the main jet. The best way to clean the jet is with a set of oxy tip cleaners.
It probably wouldn't hurt to get a carby kit and change out all you gaskets.
Hope that helps
  • SniperTeamBravo
Posted August 31, 2006 - 08:21 AM
Put in a new plug first, but it sounds like the jets are clogged, thourouhly clean the carby out and make sure you can see thru them, the jets that is.
  • pigryder
Posted August 31, 2006 - 09:16 AM
CDI box maybe?
  • frankstr
Posted August 31, 2006 - 11:26 AM
First off....Welcome to TT... :thumbsup:
Clean the carb..use air and a cleaner on the jets..
Also you might want to check the petcock assembly in the tank to make sure the screen is clean..... :applause:
