  • Instagram
* * * * * 1 votes
WR400/426/450 Jetting Database
135 replies to this topic
  • yrun
Posted June 23, 2010 - 08:47 PM
Year: 2009
Model (400 - 426 - 450): 450
Cam Timing (WR/YZ): WR
Main jet: 165
Pilot Jet: 48
PAJ: Stock
Leak Jet: 48
Starter Jet: Stock
Fuel screw (turns out): 1 1/2
Needle Model/Clip position: JD Red needle 5th clip
Grey Wire Mod (Y/N): Y
TPS Connected (Y/N): Y
Airbox Snorkel/Lid (on or off): off
AIS Removed (Y/N): Y
Airfilter Brand: Stock
Exhaust Brand: Stock (PMB Insert)
Average Altitude: 650-900
Average Temperature: 65-85F
Average Humidity: Florida-like :)
  • el bud
Posted August 09, 2010 - 05:13 AM
Year:2007
Model (400 - 426 - 450):450
Cam Timing (WR/YZ):WR
Main jet:#168*
Pilot Jet:#48*
PAJ:GYTR-AIS
Leak Jet: pluged & relocate*
Starter Jet:GYTR-AIS
Fuel screw (turns out):MERGE 1.5 OUT
Needle Model/Clip position:GYTR-AIS P-4
Grey Wire Mod (Y/N):Y
TPS Connected (Y/N):Y
Airbox Snorkel/Lid (on or off):OFF
AIS Removed (Y/N):Y (GYTR KIT)
Airfilter Brand:Twin foam
Exhaust Brand:stock, less baffel, w/p-shooter
Average Altitude:2-4
Average Temperature:high ?
Average Humidity: high?
Degree of Satisfaction (0-10):9
Additional Mods/Comments:
Used all GYTR AIS parts execpt,main,pilot,& leak as noted(*).Also installed
Merge: FMS,APS & ALJ(*) 1 turn out
What an amazing differance,And all I wanted wes to debog.
Edited by el bud, August 09, 2010 - 05:32 AM.
spell check & add ALJ setting
  • ur2silly
Posted October 04, 2011 - 05:19 PM
Year:2007
Main jet:168 (162 stock)
Pilot Jet: 48 (45 stock)
PAJ:Stock
Leak Jet: 50 (60 stock)
Starter Jet: Stock
Fuel screw (turns out):MSR 3 out
Needle Model/Clip position: Yamaha NFLR/4th
AIS Removed (Y/N):Y
Exhaust Brand:Lexx MXE slip-on
Average Altitude: 300 to 1500
Average Temperature:55-100 degrees F
Average Humidity: 85%
Degree of Satisfaction (0-10): 10
Additional comments::smashpc::banana::thumbsup:
  • Honda2stroke4life
Posted October 24, 2011 - 05:58 PM
Year:2000
Model (400 - 426 - 450):WR400
Main jet:168
Pilot Jet:45
PAJ:75
Leak Jet:200
Starter Jet:65
Fuel screw (turns out):3-1/4 OUT
Needle Model/Clip position:4
AIS Removed (Y/N):N
Airfilter Brand:UNI
Exhaust Brand:STOCK
Average Altitude:900 above sea level
Average Temperature:75
Average Humidity:75
Degree of Satisfaction (0-10):8
Additional Mods/Comments:Still dialing in seems to be a bit lean at times still,but overall runs great,and for anyone wondering I live in Georgia maybe it's the humidity...
  • Tungtran
Posted April 17, 2012 - 03:53 AM
Year:2007
Main jet:170 (162 stock)
PAJ:Stock
Leak Jet: stock
Starter Jet: Stock
Fuel screw (turns out):tusk 2 -1/8 turns out
Needle Model/Clip position: stock non- adjustable
AIS Removed (Y/N):Y
Airfilter Brand: Twin air
Exhaust Brand:08 YZ450 system
Average Temperature:28-38 degrees C
I first start with the 168 main but the bike is lean a bit. Put the 170 main and everything change . Rev like an YZ.
  • wrwest
Posted November 23, 2012 - 10:06 PM
Year: 2009
Model 2009 WR
Main jet:162
Pilot Jet:48
PAJ:110
Leak Jet:45
Starter Jet:65
Fuel screw (turns out):2
Needle Model/Clip position: YZ 450 needle - NFLR middle clip
Grey Wire Mod (Y/N):No
TPS Connected (Y/N): yes
Airbox Snorkel/Lid (on or off):On
AIS Removed (Y/N):Y
Airfilter Brand: Twinair
Exhaust Brand: Drd full system
Average Altitude:4000 to 7000 density altitude
Average Temperature:15 to 30 deg celcius
Average Humidity:40
Additional Mods/Comments Backfire screen removed from air filter cage
Merge racing spring
Merge racing brass fuel screw
  • firedog55
Posted January 04, 2014 - 05:01 PM
Year: 2006
Model: WR450F
Cam Timing: WR
Main jet: 175
Pilot Jet: 55
PAJ: stock
Leak Jet: stock
Starter Jet: stock
Fuel screw (turns out): 2 (Works Connection adj. fuel screw)
Needle Model/Clip position: GYT-R 7 grooves, clip in middle position (needle came with Yamaha AIS removal/de-restricting kit)
Airbox Snorkel/Lid (on or off): Off and air box opened up per GYT-R instructions.
Airfilter Brand: stock
Exhaust Brand: FMF PowerBomb header and FMF Powercore muffler with spark arrester.
Average Altitude: 700 ft.
Average Temperature: 10-100F yearly, currently averaging 20F
Average Humidity: 30-90% yearly, currently 64%
Degree of Satisfaction (0-10): 9
Additional Mods/Comments: Jetting has been somewhat problematic after installing the FMF exhaust system. Previously I had the stock exhaust system with a ProMoto Billet insert, 168 main, 48 pilot, needle in the middle position and the jetting was spot on. After the FMF system I had excessive decel popping and back firing. I searched this database and couldn't find what I thought was a good starting point. After talking to the guys at the local Yamaha shop this is what I went with. Decel popping/back firing gone. Spark arrester screen a light brown color.
When the weather warms up I'm sure I'll have to change the needle setting and fuel screw though to fine tune it.
  • Traskrider
Posted February 10, 2014 - 05:46 PM
Year: 2011
Model: WR450
Grey Wire Mod: Yes
Main Jet: 170
Pilot jet: 48
Leak: 45
Starter: 65
Needle Jet: Red 4th position
Fuel Screw: 1 1/2 out
AIS removal:Yes
Airbox Mod :Yes
Stock Exhaust: Pea shooter removed
Altitude: 0-2000ft
Avg temp: I live on the North Oregon Coast it's wet !!  50-70 Degrees
Degree of Satisfaction ( 0-10 ) 9
Starts up cold with Push Button + Choke, Idles fine without choke after 10 sec
  • Krannie McKranface
Posted February 12, 2014 - 07:26 AM
Year:2008
Model (400 - 426 - 450):  WR450F
Cam Timing (WR/YZ):  HOT CAMS YZ
Main jet:  170
Pilot Jet:  45
PAJ:  75
Leak Jet:  50
Starter Jet:  75
Fuel screw (turns out):  1.6875
Needle Model/Clip position: NFPQ 3RD
TPS Connected (Y/N):  YES AND CALIBRATED
Airbox Snorkel/Lid (on or off):  FULLY OPENED
AIS Removed (Y/N):  YES
Airfilter Brand:  UNI
Exhaust Brand:DUBACH RACING SS FULL SYSTEM
Average Altitude: 2000 FT
Average Temperature: 20
Average Humidity: 75
Degree of Satisfaction (0-10): ELEBUN
Additional Mods:
CARB:  APUMP UPGRADE (NEWER CHECK VALVE SYSTEM) USING 2008 CRF COMPONENTS
             ZIPTY RACING HOT START NUT (ALUMINUM)
 MOTOR:  FULL STAGE 3 PORT AND POLISH (AS RACING)
                  BARNETT CLUTCH PACK
                 .060" CLUTCH SPRING BOLT SPACERS
IGNITION: DYNATEK FS IGNITION MODULE
                 STOCK MAP # 3
                  MODIFIED MAP # 2: AGGRESSIVE ADVANCE CURVE, WITH ALL 1+ ADVANCE
Edited by TheKoolAidMadeMeSick, February 12, 2014 - 07:29 AM.
  • angello714
Posted July 18, 2014 - 12:25 PM
Year: 1999
Model (400 - 426 - 450): 400
Cam Timing (WR/YZ): wr
Main jeticon1.png: stock
Pilot Jet: stock
PAJ: stock
Leak Jet:stock
Starter Jet: stock
Needle Model/Clip position: 3 clip stock needle
Grey Wire Mod (Y/N): yes
Airbox Snorkel/Lid (on or off): one
AIS Removed (Y/N): no
Airfilter Brand: uni
Exhausticon1.png Brand: stock with spark arrestor
Average Altitude: 89FT        Garden Grove California
Average Temperature: 65.6F
Average Humidity: 62%
Degree of Satisfaction (0-10): 8 being that i am happy. the other 2 being that i think there is something that needs fixing but not sure yet. still playing with the air/fuel - pilot screw.
Additional Mods/Comments: no mods other than i am running a 14t front sprocket and 48t rear sprocket, 120 rear desert tire with 15psi front and rear.
i had graduated 2013 mmi phoenix arizona in YamaPro. they only teach you so much just to get you on your feet. i just got my street legal wr400fl this year. it was not running and needed some work. got her for $1,500. now she is set up for the desert and running pretty smooth. i am about ready to put her up for sale in a bit. she will be going for an average price for a running street legal and current tag WR400fl
  • dolan4265
Posted March 07, 2015 - 11:08 PM
Year: 99
Cam Timing (WR/YZ): yz
Main jet: 175
Pilot Jet: 48
Fuel screw (turns out): 1 3/4
Needle Model/Clip position: jd blue 5th
TPS Connected (Y/N): N
Airfilter Brand: K&N
Exhausticon1.png Brand:  staintune
Average Altitude: 0 - 100m
Average Temperature: 24 c
Additional Mods/Comments: vortex cdi, wiseco high comp piston, loud as f@#k exhaust, will rip your arms off
  • GreenRide
Posted May 27, 2015 - 08:59 AM
WR450F 2003
WR Timing
168M
48P
40LEAK
Stock air jet
Stock Power jet
Stock needle set @ clip pos 5
TPS Connected
Altitude 0 - 100 m
Average temp 15C - 30C
Air box removed
GYTR Baffle
SCAR adjustable fuel screw
Satisfied 9/10
  • Agazza
Posted November 09, 2015 - 02:36 AM
Year:                                         2008
Main jet:                                    Stock
Pilot Jet:                                    Stock
PAJ:                                          Stock
Leak Jet:                                Stock
Starter Jet:                                Stock
Fuel screw (turns out):              ?
Needle Model/Clip position:      ?
Grey Wire Mod (Y/N):               Yes
TPS Connected (Y/N):              No
AIS Removed (Y/N):                 Yes
Exhaust Brand:                     YZ header, cleaned out original muffler
Average Altitude:                      300 ft
Average Temperature:             6 celsius, top 32 celsuis, bottom 35 celsius below
Average Humidity:                   80-95 %
Degree of Satisfaction (0-10):  4
I have the bog problem and i need some guidence for fixing this.
English is not my native language but i googled most stuff here, but if someone would please help me with photos with what i need to buy and to do, or just general directions, i would be a most grateful.
The problem started when i opened up the exhaust for YZ standards.
I read the how to eliminate bog thread, but i do not understand it all. And remember that i have never opened a carburator
Best regards
Edited by Agazza, November 09, 2015 - 02:41 AM.
  • Turbo-Fan
Posted November 14, 2016 - 09:52 PM
Year:  2008
Main jet:  Unknown
Pilot Jet:  Unknown
PAJ:  Unknown
Leak Jet:  Unknown
Starter Jet:  Unknown
Fuel screw (turns out):  N/A
Needle Model/Clip position:  GDDUR, No. 3 groove
Airbox Snorkel/Lid (on or off):  Lid on, snorkel removed
Exhaust Brand:  Stock with silencer/spark arrestor removed
Average Altitude:  6,000'-9,000'
Average Temperature:  55F-85F
Average Humidity:  10%
Additional Mods/Comments:  Just got the bike and am very pleased.  Pilot jet and Main jet seem very close to correct, had to incrementally raise the Needle clip 2 notches to eliminate 1/4-3/4 throttle overly rich condition.  FMF exhaust in the near future with edits to follow.
  • jamesm113
Posted December 29, 2016 - 11:22 AM
Year:
Cam Timing (WR/YZ): 06 YZ exhaust cam
Main jet: 168
Pilot Jet: 48
PAJ: stock (70)
Leak Jet: Between 40 and 50.  40 is a bit too rich, 50 lacks a bit of crispness.
Starter Jet: stock (72)
Fuel screw (turns out): 2.5-3
Needle Model/Clip position: JD Red-4
Airbox Snorkel/Lid (on or off): snorkel removed
Airfilter Brand: Twin Air/Uni/No-toil
Exhaust Brand: FMF Q4.  Stock header
Average Temperature: 70
Average Humidity:
Degree of Satisfaction (0-10): 9.5
Additional Mods/Comments: Followed Krannie's recommendations for the 2008 CRF450F accelerator pump kit (Honda Part# 16021-MEN-A01), and the tokyo mods accelerator pump spring.  Highly recommend that combo - the bike rips and has better throttle response than stock YZ's and fuel injected bikes IMHO.
I have been experimenting with different leak jets.  50 eliminated the bog, but wasn't perfect.  40 is a little too rich.  Next attempt will be a 45.
For some reason, my bike likes a richer pilot circuit than others.  It starts first kick hot or cold. E-start works 90% of the time, even though YZ cams are known for having too much decompression for e-start to work.
Over 6,000 feet = JD Red-3, 165 MJ
Over 9,000 feet = JD Red-3, 160 MJ
  • nks731
Posted January 10, 2017 - 11:01 AM
Year: 2002
Model (400 - 426 - 450): YZ 426
Main jet: 168
Pilot Jet: 48
Starter Jet: Stock 72
Fuel screw (turns out): 3/4
Needle Model/Clip position: Y356  4th
AIS Removed (Y/N): ?
No grey wire mod.
Exhausticon1.png Brand:  FMF Silencer
Average Temperature: WInter 65 Summer 110
Humidity: Dry
Degree of Satisfaction (0-10): 9/10
Additional Mods/Comments: Gearing 14/47, IMS 3 Gal.
