New life for an old friend.
19 replies to this topic
  • atkxr600
Posted August 29, 2006 - 06:17 PM
Well in an attempt to stay motivated, I'm postings my intentions of resurrecting my old Hare Scrambles bike.
Heres a couple of pics of the 91 motor I built for it. The color of the paint came out a little dark, but if thats the worst thing I run into, I'll be happy.
http://www.thumperta...achmentid=26021
http://www.thumperta...achmentid=26022
http://www.thumperta...achmentid=26023
  • atkxr600
Posted August 29, 2006 - 06:19 PM
Heres the old oil leaking 86 mill.
http://www.thumperta...achmentid=26024
http://www.thumperta...achmentid=26025
  • atkxr600
Posted August 29, 2006 - 06:21 PM
The CR250 forks are on.
http://www.thumperta...achmentid=26026
  • atkxr600
Posted August 29, 2006 - 06:23 PM
The rear disk brake and 18" wheel from a 91 XR6 are on.
http://www.thumperta...achmentid=25873
http://www.thumperta...achmentid=25877
  • slepe67
Posted August 29, 2006 - 06:24 PM
Good on ya! I havent seen one of them in a while! Good luck!
  • atkxr600
The frame is all cleaned and ready to start re assembly;
http://www.thumperta...achmentid=26028
http://www.thumperta...achmentid=26027
  • atkxr600
Posted August 29, 2006 - 06:27 PM
Thanks, I hope to have the lion share of the work done this weekend.
  • suharianu
Posted August 29, 2006 - 09:52 PM
NICE WORK,how did you fit those cr forks?makes me thinking
  • atkxr600
Posted August 30, 2006 - 03:22 AM
I bought a 91CR250 with a bad motor ($200). When I ordered the kit from ATK way back when, it was designed to accept components from an 86 XR600.
The distance between the upper and lower triple clamps between those two bikes is the same, as is the diameter of the top steering stem bearing. The bottom bearing on the stem is larger on the CR. Where as the top and bottom bearings on the XR are identical. The stem on the XR is the same diameter from top to bottom. The stem on the CR has a larger O.D. at the bottom bearing.
Seeing as how the larger CR bearing was not going to fit into my frame, I needed to devise a way to use the clamps from the CR, with the bearings for the XR. I pressed both stems out of the lower clamps, then made a sleeve that would slide onto the XR stem and increase its O.D. where it fit into the CR lower clamp.
This was made on the a lathe, out of billet aluminum, pressed onto the XR stem, then the XR stem was pressed into the CR lower clamp. This made the swap a bolt on. The steering stops needed to be modified to keep the top clamp from hitting the tank at full lock.
It was a fairly easy swap, but then I'm a Tool & Die maker by trade, with an apprentice and a shop full of equipment at my disposal. But if there was a small machine shop in your area, all that would need to fabed up is that sleeve.
Sorry for the long post, I should have taken more pics. Then less typing.
  • goblin127
Posted August 30, 2006 - 06:43 AM
Very nice. Good going
  • x400r
Posted August 30, 2006 - 06:59 AM
What paint did you use for the engine? Where did you find it?
  • SniperTeamBravo
Posted August 30, 2006 - 07:02 AM
I just say you are doing great work there on a neat hybrid! I like the ATK/XR deal and especially since the ATKs took XR wheels and suspension that is a good swap on the CR stuff. Keep up posting of the pictures of the progress! Im interested in seeing it complete. What coloure is the frame going to be? Also, love the coloure on the motor, like the XR650R which is exactly what Im going to do on my 96 XR610R Stupidmoto.
  • atkxr600
Posted August 30, 2006 - 07:22 AM
Thats a Dupli-color paint from a rattle can. I bought it Auto Zone, its made for mag wheels, the color is bronze. I kept the empty can, and SKU # in case I need some more. If anyone needs it, I can post it here, or PM me.
Thanks Mike.
  • atkxr600
Posted August 30, 2006 - 07:24 AM
This fall the frame will be staying blue, I want to get it together and ride it this fall. I plan to pull it back apart this winter, and am thinking I'll re-powder coat in the nickel color then.
  • atkxr600
Posted September 03, 2006 - 05:30 AM
Heres the products I used to paint the motor, the stripper is expensive ($44 per gal.). And very caustic, follow the label instructions if you use one of these.
I stripped all the old paint off, then cleaned the surface with the thinner, then paint.
http://i6.photobucke...tn_CIMG1476.jpg
  • atkxr600
Posted September 03, 2006 - 05:33 AM
Heres a few shots of my redneck bike lift.
http://i6.photobucke...tn_CIMG1471.jpg
http://i6.photobucke...tn_CIMG1475.jpg
http://i6.photobucke...tn_CIMG1473.jpg
  • atkxr600
Posted September 03, 2006 - 05:36 AM
Installed motor in frame, I took a few extra pics of the motor mounts that ATK designed for this swap.
http://i6.photobucke...1481_edited.jpg
http://i6.photobucke...1479_edited.jpg
http://i6.photobucke...00/CIMG1486.jpg
http://i6.photobucke...00/CIMG1485.jpg
http://i6.photobucke...00/CIMG1484.jpg
http://i6.photobucke...00/CIMG1483.jpg
  • redrider91
Posted September 03, 2006 - 06:59 AM
That looks very nice, Cant wait to see the whole thing fully assembled, Sweet!
  • atkxr600
Posted September 17, 2006 - 06:08 PM
Well we are moving along slow but sure. I finished up the airbox and electrical tonite. I realized that if I just put the exhaust on I could fire it up. Took a few kicks, but she came to life. Got a little ahead of myself, but it was neat to hear it run.
  • LandSharkGT
Posted September 17, 2006 - 06:36 PM
That looks like it is gonna be one Bad A$$ ride!
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  29 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 3 replies
