pointers for potential 426 owner
6 replies to this topic
  • srgnz
Posted August 29, 2006 - 03:25 PM
I am looking at buying a used 2003 426WR... are there any common problems with this model which I should look out for?
  • clark4131
Posted August 29, 2006 - 03:28 PM
You're going to have be a little more specific. Are you buying a 2003 or a WR426? You can't do both :thumbsup: ...SC
  • srgnz
Posted August 29, 2006 - 03:38 PM
Sorry - I have never owned a Yamaha before, and don't know the model succession sequence.
It is definitely a WR426. The owner has it advertised as a 2003.
When did they drop the 426 for the 450?
  • byggd
Posted August 29, 2006 - 03:44 PM
The last year of the 426 was 02 and the 450 started in 03. Does it have an e start or a compression release?
  • srgnz
Posted August 29, 2006 - 03:59 PM
No E-start. Compression release on the bars.
Is there anything nasty to look out for on the '02? WR426 ??
  • GCannon
Posted August 29, 2006 - 04:05 PM
2002 last year of 426.
Not too many problems I am not sure but if NZ production is the same as AUS then all you need to do is remove air box lid buy a pipe and re jet the carb and you will have a great bike. I would consider respring and revalve the suspension at a later date. Get the carb tuned nicely and kick starting will be much easier once you learn the drill.
Good luck
  • byggd
Posted August 30, 2006 - 04:01 AM
As already stated the 02 426 it a pretty bulletproof bike once you get it dialed in. If you want to avoid the decompress drill all together you can always do this mod. I did and I must say it was well worth it! :thumbsup:
