Cylinder Question.
1 reply to this topic
  • honda88
Posted 27 August 2006 - 06:53 AM
I'm pretty sure I know what the answer is but I just want too make sure.I have a RPM Ice Cube 276 and I am putting in a new piston.The cylinder walls have no cross hatch at all does it need to be ball honed(No wise cracks) ,Thanks.
  • Chokey
Posted 27 August 2006 - 07:01 AM
A ball hone will not cut a new cross hatch into the bore surface. If you've thoroughly cleaned the surface, and there truly is no cross hatch left, the plating is worn out.
