front wheel bearings
3 replies to this topic
  • theclone
Posted August 26, 2006 - 09:55 PM
I need to replace them. slight wobble. Besides the actual bearings, what else should I replace, if anything? clicky
you can just tell me the numbers if you're feeling lazy haha :thumbsup:
oh yeah, any special tools to remove the old bearings and put in the new one?
  • quailboy
Posted August 26, 2006 - 09:59 PM
get a seal and bearing kit and you should be fine. what i have used to get bearing out in a similar situation is a hydrualic press. not sure if you need or should use one for this.
  • theclone
Posted August 27, 2006 - 10:57 AM
seal and bearing kit?
  • Motocross26
Posted August 27, 2006 - 01:53 PM
Pivot Works makes one.
No special tools. Remove the old bearings with a hammer and punch, try to get them out as evenly as possible. Put the new ones in the freezer for a few hours and install them with a socket that is the same size as the outer race of the bearing and hammer.
Make sure to pack the bearings with grease before you install them. Bel-Ray waterproof grease is good stuff.
  • Hot  47 replies
  • Hot  50 replies
  • Hot  113 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 5 replies
