Bike won't start
14 replies to this topic
  • HondaXR650L
Posted August 26, 2006 - 03:36 PM
Fired my "L" up then shut it off with my key, then it would not fire back up. Changed the spark plug, no help. The bike is in neutral the kick stand switch works just fine, recharged the battery because I ran it down, then checked the coil at the Honda shop and it was fine. Ran a voltage tester on the wires and cranked the starter, and a strange thing happened, there was no increase of voltage until I took my finger off the start button, then the voltage meter jumped from .04 to .71 and back to .04. I tried that a couple of times and each time it was the same. Is this normal? :thumbsup: Any help is appreciated.
  • goblin127
Posted August 27, 2006 - 05:26 AM
Checked the kill switch yes?
  • HondaXR650L
Posted August 27, 2006 - 12:37 PM
Yes, I did that, I turned the key off not the kill switch. I also made sure that the bike was in neutral and also tried to compression start it, and NOTHING!!! The kick stand is also in the up position and both lights work properly. :thumbsup:
  • frankiewhipit
Posted August 27, 2006 - 12:54 PM
play around with the kill switch, i never use mine (always the key) yet occasionally it will not fire up, flip the switch a couple of times & it starts right up :thumbsup:
  • XR650L_Dave
Posted August 27, 2006 - 05:03 PM
Short both clutch-switch leads to ground to bypass all the safeties.
Its cranking OK?
Make sure the carb is getting gas- loosen the drain screw at the bottom of the bowl.
D
  • HondaXR650L
Posted August 27, 2006 - 09:25 PM
Checked the kill switch and nothing. I have an Eldelbrock and ran the gas thru no prob. The bike cranks when I pulled the spark-plug the piston was moving, I flooded the bike the fist night trying to get it started and charged the battery, I am trying to avoid taking this to a Honda shop and paying a lot of money. :ride: I will try to adjust my clutch because I like it loose, but the part that bothers me is that I fired it up and then shut it off and 30 sec. later nothing... :thumbsup: I really do appreciate all the help in figuring this out.
  • Motosprtman
Posted August 28, 2006 - 05:30 AM
Blown fuse?
  • frankiewhipit
Posted August 28, 2006 - 11:19 AM
you can remove the front number plate, find the connector from the ign switch, jump the 2 big wires & that will eliminate the key switch.
  • SniperTeamBravo
Posted August 28, 2006 - 11:23 AM
starter relay croaked Ill be willing to bet.
  • HondaXR650L
Posted August 28, 2006 - 04:34 PM
Blown fuse?
First I checked the kill switch, then that it was in neutral, then the gas, then the fuses. I am getting some juice but not a spark.
  • BluezookS
Posted August 28, 2006 - 07:52 PM
Could you have a false neutral? I would try cycling all your switches, wiggling them then try again. Put it in gear rock around then neutral again.
You never know sometimes we do something silly that we stump ourselves.
  • HondaXR650L
Posted August 29, 2006 - 03:33 PM
Try-ed that when I went for the compression start. I will be taking apart the kill switch and the kick stand switch.
  • 52wheelz
Posted August 29, 2006 - 05:19 PM
Have you tested the CDI to see if it is good. I had an XR250 that wouldn't start and it was a bad CDI. Unfortunately, these are expensive to replace.
  • 52wheelz
Posted August 29, 2006 - 05:24 PM
Another thing to check is a possible vapor lock in the fuel flow. Take the gas cap off your gas tank and see if it will start and run. I once had a vapor locked PW50 that would run for a few min. and then shut off. The one way valve on the vent tube of the gas cap had been reversed so everytime we opened the gas tank, we provided ventilation but as soon as we put the cap back on, no gas would flow. I have also seen this happen on an XR600R where the gas cap would not allow fuel to flow. I know there is not vent tube on the stock XR650L gas cap, but the cap could still be the problem.
  • HondaXR650L
Posted August 30, 2006 - 07:09 PM
Let the Public Humiliation Begin!!!
Blown fuse?
I checked the fuses, really I did. :thumbsup: XRLJimmy came over and HondaXR650R shortly behind him to help me out and get the bike started, Jimmy found of all things, a blown fuse, now the bike works great. Yes, I wanted to post this before the two of them did, and there you have it. I just wanted to finish this post off with a very heart felt thank you to 2 good friends that took time out of their busy schedules to help this MORON out. :applause:
  • 4 replies
  • 3 replies
  • 9 replies
Washington
  • Hot  32 replies
  • Hot  186 replies
