does using the 06 piston in the 05 boost compression to 13.5:1 ?
06 piston in 05?
Started by mrricky, Aug 26 2006 12:39 AM
4 replies to this topic
Posted 26 August 2006 - 09:27 AM
no, and from what i hear it wont work on your 05 period, its a completely different part number, plus you wouldnt want to make a stock piston run 13.5:1, its ment to run 12.5:1, if you want more compression just buy a high comp. piston
Posted 26 August 2006 - 12:22 PM
NO it does not boost your compression. But go ahead and try it if you want.
Posted 26 August 2006 - 11:15 PM
i thought the 06 ran 13.5:1 with a stock piston. and the 05 12.9:1 and the only diff was the piston. o'well maybe not
Posted 27 August 2006 - 07:23 AM
The 06 piston will fit on the 05, the major difference is that the 06 uses a thinner compression ring. If you run the 06 piston you need to run the 06 ring set.
