Quick valve check question
2 replies to this topic
  • MX-WFO
Posted 25 August 2006 - 06:35 PM
Getting ready to check my valves for the first time. Once I have it set to TDC with the cam lobes faceing to the rear (intake), the marks set on the right side view hole and the marks set on the cam sprocket, I CAN check all four valve clearances at the same time right? Thanks in advance...
  • 919_250x
Posted 25 August 2006 - 06:54 PM
Yes, once you're at TDC. Check all the valves.
Best article on Thumpertalk:
How to check and Adjust the valves on your 250 (w/Pics)
A must read!
Good Luck
  • skipn8r
Posted 25 August 2006 - 07:58 PM
Yes, you can.
