Fuel?
29 replies to this topic
  • arnie230
Posted August 24, 2006 - 03:47 PM
I am new to the 4 stroke world and I am wondering what fuel to run in my new '06 yz450F? Do I have to run high dollar race gas?? I have been a 2 stroke guy 4ever and need some advice....Thanks!!!!!!
  • 450_rider
Posted August 24, 2006 - 03:50 PM
All you need is good fresh premium fuel.
  • flintlock28
Posted August 24, 2006 - 04:27 PM
Yep, what 450 rider said....
Motocross Action magazine recommends 91 Octane to about 94 octane (R+M)/2 method.
The (R+M)/2 method is the typical method you'll find on U.S. gas pumps. THe only time you'll need to run higher octane, is only if you change over to a high compression Piston.
  • TexN343
Posted August 24, 2006 - 04:31 PM
What is the disadvantage from from regular unleaded? I'm thinking it's 87 octane?
  • barch88
Posted August 24, 2006 - 04:39 PM
My front fender sticker, and manual says "Premium Unleaded Only" so that is what I run.
  • quailboy
Posted August 24, 2006 - 04:43 PM
cheaper gas will give you worse performance and will dirty your carbs. its best to run the best fuel and oil that you can afford. makes things last longer
  • flintlock28
Posted August 24, 2006 - 04:47 PM
At 87 Octane, you may experience detonation (Ping).
Short term, a mild amount won't hurt anything, but if you get detonation over a long period of time, you're going to damage your Engine. Ping is caused when the Piston is still coming up, and the fuel is prematurely igniting, trying to ram the Piston back down as it's still moving up....NOT good!! Higher octane fuel (say 91) won't prematurely ignite as easy as 87, thus no Ping.
The manual for my 04' Yz450f calls for 95 RESEARCH OCTANE (which translates to 91 octane (R+M)/2 method) Use 91 minimum for a STOCK engine.
  • 450_rider
Posted August 24, 2006 - 05:05 PM
So is ping kind of like your engine acting like a diesel
  • YZ117
Posted August 24, 2006 - 06:24 PM
AVGAS for sure!
  • flintlock28
Posted August 24, 2006 - 06:27 PM
Yes, Ping is similar to a diesel since compression is firing off the fuel.
What is happening is that as the Piston is going up, it is generating heat as it compresses the fuel/air mixture, and unfortunately it is igniting the fuel/air mixture before the piston reaches TDC (top dead center), even before the spark plug fires.
Just imagine the kind of force that piston is encountering as it's making it's way up, and getting slammed by the pre-maturely lit fuel/air mixture!!! Yikes, Not Good!! Eventually, you're gonna get piston damage. Every engine is designed to use a certain Octane Rating which is nothing more than a rating to prevent ping (a certain value).
With these typical 4 strokes (Honda, Yamaha, Kawisaki, etc.) they are designed to use about 91 Octane. If you go lower then this value, than it means the fuel will be more prone to ignite too early (ping), thus subjecting your Piston to a downward "push" as it's still coming up. As long as you meet the Octane value rating by the Engine designers you'll be o.k.
You can use higher than required Octane (let's just say you use 100 octane for your bike) and that will be fine, But why spend more money for a higher priced fuel that won't result in any more power???? Remember, Octane Rating is nothing more than a rating for preventing 'Ping" or "knock", it has nothing to do with Cleanliness of Fuel, or
Quality of Fuel, or energy content. People seem to mix this up all the time.
So on a STOCK bike, just use 91 octane or slightly more.......I usually use BP 93, since it's common around here. If you switch to a Higher compression Piston than STOCK, THAN you will have to up the Octane rating because know you have increased the cylinder compression, and that 91 octane fuel will probably pre-ignite (ping) with the higher compression.
hope this helps.
Don
  • flintlock28
Posted August 24, 2006 - 06:35 PM
AVGAS is another INCORRECT fuel to use....
I don't feel like posting all the reasons why....but let's just say that AVGAS is designed to be used by Airplanes running at much higher Altitudes, at nearly CONSTANT RPM's. HOW MANY OF US RIDE OUR MX/OFFROAD BIKES AT NEARLY THE SAME RPM'S???? it is basically a proprietary fuel, designed for the narrower applications of Airplanes. Plus it costs quite a bit more money.....
A number of the MX magazines, stated the same things and said "Don't use it"
  • YZ117
Posted August 24, 2006 - 07:06 PM
I was just kidding.
  • arnie230
Posted August 25, 2006 - 01:37 AM
I had to ask as the manual recommends 95 octane or higher. I wonder when Sunoco stopped selling there 94 fuel?
  • barch88
Posted August 25, 2006 - 03:19 AM
I thought it recommended 91 or higher...not 95.
  • jamiehughes
Posted August 25, 2006 - 04:02 AM
i run the race gas in mine and it seems to make it not pop so much on hard deceleration,when its real warm outside. seems to make the bike run a little cooler.
  • ncmountainman
Posted August 25, 2006 - 04:27 AM
thats because higher octane fuel will genarally make your bike run richer,one good thing about race fuel is that it is usually more consistant than pump fuel,pump fuel actually changes content seasonally and regionally :thumbsup:
  • Desert Rat 450
Posted August 25, 2006 - 04:44 AM
:thumbsup: enough said.
  • Ga426owner
Posted August 25, 2006 - 07:49 AM
AVGAS for sure!
a big no no................ :thumbsup:
use premium unleaded or use VPU4
VPU4 is expensive but adds 2-3hp and burns much cleaner than pump gas. I use this exclusively
  • Daffy Duck
Posted August 25, 2006 - 07:58 AM
I think low octane petrol can cause pre-ignition which means the petrol air mix explodes before it should. This is bad in a car (knocking) but it is really bad in a high compression aluminium engine..
Posted August 25, 2006 - 09:01 AM
flintlock, you're almost entirely correct. Good job. :thumbsup: But there is a fundamental difference between detonation in a gas engine and compression ignition in a diesel, or in a gas engine, for that matter.
In a diesel, even though the fuel is ignited by the heat of compression, the fuel burns over a period of time as it is injected into the cylinder, not all at once. In an old, carboned up gasoline V8, you can have a condition under which the heat of compression can cause a hoe spot in the carbon to glow and ignite the fuel, but it still burns outward in a wave from that point.
But Detonation, whether it is the partial detonation of the last bit of the fuel charge that you hear as pinging, or serious early detonation, is the instantaneous combustion of all the remaining fuel in the combustion chamber, all at the same time. It is extremely dangerous. Rocks in the cylinder would actually better for the engine.
Arnie, the manual says 95, but that is Research Octane, which is generally about 5-8 points higher than the Motor Octane number for the same fuel. U.S. gas pumps are marked with the average of both of these (shown as (R+M)/2, as was mentioned), so 91 at the pump is the equivalent of 95 research, or even higher.
Race fuels change the jetting requirements for reasons related to fuel chemistry, not their octane rating. Some high and low octane fuels behave differently for the same reason, but the octane rating itself tells you ONLY how resistant to compression detonation the fuel is, and nothing whatsoever else.
  • 5 replies
  • 0 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  50 replies
