Acerbis Handguards with ProTaper Bars
6 replies to this topic
  • redrocket190
Posted August 24, 2006 - 09:36 AM
I put ProTapers on my '99 WR400F and wanted to re-install my Acerbis handguards. The bit that goes in the end of the bar appears to come in two flavors: 7/8" aluminum i.e. Renthals and 7/8" stock steel. The former is to big to go inside the ProTapers. So I ordered a "ProTaper kit". When this arrived it is for mounting the end that goes on the bars near the clamp. So I am still left with the bit that goes in the bar-end being to big for the inside diameter of the PropTaper bar. Do I need ream the bar out, or am I missing something? Thanks!
  • simon@vic
Posted August 24, 2006 - 12:43 PM
pull off the rubber tube/sleeve thing.
  • redrocket190
Posted August 24, 2006 - 04:41 PM
If there were anything rubber around to pull off, I would, but there isn't. Next!
  • nut
Posted August 24, 2006 - 06:39 PM
redrocket i sent you a pm. later
  • simon@vic
Posted August 25, 2006 - 07:30 AM
take a picture................ :thumbsup:
  • o2golfpar
Posted April 20, 2009 - 10:50 AM
I have the exact same problem with my 2008 WR. What size bar inserts kit is needed that is small enough to fit in the inside of the bar? Help? Suggestions?
  • wr450mazz
Posted April 21, 2009 - 01:23 AM
I had the same problems when i fitted the pro taper bars as well.
The gen-yamaha bar end inserts seem to be longer than most aftermarket hand guards.
I had to get a drill bit the same inside id as the bars and drill in a little further until the inserts and guard ends were flush with the bars.
Been aok since.
