Neoprene Washer on Drain Bolt (650L)
6 replies to this topic
  • TARFELE
Posted August 24, 2006 - 03:41 AM
Has anyone used a neoprene washer on the side oil drain bolt? I just put a new metal washer on because it was dripping very slow from the side drain bolt. After the new washer it is still dripping. Just wondering if anyone uses the blue neoprene washers?
  • TARFELE
Posted August 26, 2006 - 04:31 AM
I figured at least one smartass would put something!
  • CTXr650L
Posted August 26, 2006 - 04:34 AM
my bike only has 120 miles on it, i havent even changed the oil yet... so havent experienced any leaking problem yet.
  • goblin127
Posted August 26, 2006 - 06:05 AM
No leak on mine,and I have switched it over to amagnetic one. The drain for the oil res. leaks alittle.
  • cleonard
Posted August 26, 2006 - 06:29 AM
Take the drain bolt with you to an autoparts store and get a washer. Neoprene is too soft and will tear under the bolt. There are two main kinds that are not metal. First is plastic, it's harder than neoprene. THe second is a fiber type. Either will work. Since they are softer than metal, they don't last forever. You have to replace them every 5 or so oil changes.
  • frankiewhipit
Posted August 26, 2006 - 07:07 AM
They do make metal drain plug gaskets with neoprene centers ( oem on american cars ) they work well :thumbsup:
  • TARFELE
Posted August 26, 2006 - 12:30 PM
Thanks guys, I have some of the blue plastic drain plug washers but I was wondering about the neoprene. I will try the plastic.
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
