White Brothers E2 Rubbing on rear wheel
15 replies to this topic
  • muddza
Posted August 24, 2006 - 12:55 AM
Has anyone else had this occur? Spent AUS $700 on a pipe that rubs on the back wheel. I am thinking that I may have twisted the sub-frame in my loop out that bent my original pipe, although everything lines up and it doesn't seem like it. I'm about to add a spacer or two to the mounting points to solve this. :thumbsup:
  • Dustin_Mabro
Posted August 24, 2006 - 04:32 AM
i just asked this question myself because i thought the reason was my spring was cut shorter by the origional owner.
The answer i was given that seemed the cheapest was to jam a bunch of washers or something to gap the can away from the tire.
good luck :thumbsup:
  • kid on a 426
Posted August 24, 2006 - 07:35 PM
Thats the hokey way to fix it. If your pipe is rubbing then your subframe is bent. Just bend it back or get a new one.
  • David37
Posted August 24, 2006 - 07:54 PM
I had the same problem on my WB E2 pipe. I purchased a longer bolt and used a 3/8" wide spacer where the muffler bolts to the subframe. I used an old inner bearing (perfect sized spacer) left over from a recent rebuild of the lower rear shock bearing.
  • Way Fast Whitey
Posted August 24, 2006 - 08:03 PM
mine rubs too, its the aluminum pro 2, its got a bunch of tire marks, makes you wonder. :thumbsup:
i was gonna throw in some washers, but the marks come off so i'll leave it
  • muddza
Posted August 25, 2006 - 12:16 AM
Makes you wonder alright. I think I will do the washer thing.
  • Way Fast Whitey
Posted August 25, 2006 - 07:14 AM
i thought about it and screw the washer thing. I'm gonna go cut something on the lathe right away :thumbsup:
  • Ga426owner
Posted August 25, 2006 - 07:53 AM
That will work - my Alum Pro2 does not rub on my 06 - I use stock rear tire size
  • Raven1911
Something to cosider too is if you have a wider tire on the back of the bike. If its wider than the stock tire then it will be more likely to rub. Otherwise use the washer to space it out. Its not a hokey thing to do. I did it on my bike and you can't even see it.
:thumbsup:
  • Dustin_Mabro
Posted August 25, 2006 - 08:51 AM
Its not a hokey thing to do. :thumbsup:
thanks...kid hurt my feelings :ride:
  • Way Fast Whitey
Posted August 25, 2006 - 08:56 AM
i think the millville has big side lugs, so this may be the problem :thumbsup:
  • muddza
Posted August 25, 2006 - 12:04 PM
I just put on a new Michelin Starcross, but kept the original size, so this shouldn't be the problem.
  • Ga426owner
Posted August 25, 2006 - 12:43 PM
ahhhhhhhhhh yes! my favorite tires MS3's
  • jr_vw2
Posted August 25, 2006 - 03:52 PM
My E2 rubs too. I used the spacer that came with it....the one you are suposed to use to space your number plate (yz426) it is about 3/8 thick and the tire STILL rubs. guess I need to add more to it.
  • Way Fast Whitey
Posted August 25, 2006 - 05:02 PM
i forgot about that thing, now that you mentioned it i'm gona go put it in :thumbsup:
  • muddza
Posted August 28, 2006 - 12:04 AM
That spacer didn't do squat
