02 YZ 426F ,,Worth buying? need input
4 replies to this topic
  • missionary
Posted August 23, 2006 - 04:10 PM
Ok I am looking at buying a yz 426f year 2002. What advice can you give me. It looks fairly unused, what are the pros and con about this bike. I also need "what to look for" about a 2003 yz 250f. Thanks
  • mxgene
Posted August 23, 2006 - 05:47 PM
First thing to do if you buy it, put an '03 450 exhaust cam in or replace it with a hot cams.
It will be so much easier starting.
  • never59
Posted August 23, 2006 - 06:11 PM
I had an 02 426. Pro's are the motor is practically bombproof! The con's are it is heavy and can be hard to start at times.
  • Yamahondaha
Posted August 23, 2006 - 06:19 PM
I kinda like having the decompresser lever and advocate the mechanics first rule of thumb: "If it ain't broke don't fix it"
The pros are: :thumbsup:
13,500 rpm rev limiter (2 stroke performance).
Great suspension.
Reliable and durable.
Lots of parts available.
The cons are: :ride:
Hidden spark plug needs seat and tank off to get to.
Valve adjustments require the cam(s) to be removed.
Carb jetting can be tricky (get a JD jet kit).
Your arms will be yanked out of the sockets! (the bike kicks like a race horse)
  • Yamahondaha
Posted August 23, 2006 - 06:20 PM
Once it is jetted correctly with a JD jet kit it will only need one kick to light it up.
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • On January 15, 2017
