WR400 Hotcams shimming issues!
2 replies to this topic
  • JJHayesIII
Posted August 23, 2006 - 01:17 PM
I just checked the clearances with my new cams (hotcams) installed, and am getting some seemingly bad numbers.
New shim sizes come out as follows:
Ex: .275mm, .345mm
In: .229mm, .202mm, .204mm
Here's the data I'm using:
EX (hotcams clearance spec = .20mm):
Clearance: .305mm, .381mm
Current Shim: 170, 165
IN (hotcams clearance spec = .15mm):
Clearance: .203mm, .178mm, .178mm
Current Shim: 176, 174, 176
I guess the only one that looks REALLY bad is the Right Exhaust valve, at .345mm...can I even get a shim in that size? Is my math wrong? Are the cam journals fried?
I'd appreciate any help here, as I want to go to the dealer and get my shims!
Thanks!
- JJ
  • nitronaf
Posted August 23, 2006 - 01:59 PM
yes u can
my hotcams shimkit goes up to .350
  • JJHayesIII
Posted August 23, 2006 - 02:27 PM
looking at it again, I think I calculated them wrong.
Using this chart for an 03 wr450f, I get results that are seemingly more reasonable:
EX: 175, 180
IN: 180, 180,180
