IMS 4.0 on an XR600
5 replies to this topic
  • JGalt
Posted August 23, 2006 - 06:22 AM
Does anyone know if you can fit a second petcock on the IMS 4.0 tank? I just noticed that there must be a half gallon in the right side that can't get to the engine, or am I wrong?
  • SniperTeamBravo
Posted August 23, 2006 - 07:36 AM
Is there a boss on that side with a coverplate on it with a petcock mount under it? My Acerbis 5 gallon doesn't do that or have provision for a second petcock, but my Acerbis 7 gallon tank has a petcock on both sides for that reason....
  • JGalt
Posted August 23, 2006 - 11:36 AM
There is no boss on the right side of the IMS tank. I suspect I would have to cut a hole and epoxy a fitting on. Someone has had to have crossed this bridge before.
  • rmhrc630
Posted August 23, 2006 - 11:47 AM
Mate drop the idea
You do not need 2 fuel taps.
Lean the bike over and the fuel runs to the left.
  • JGalt
Posted August 23, 2006 - 12:16 PM
I use the XR mostly for dual sporting on flat roads hence the desire to put a second petcock.
  • Livermore
Posted August 23, 2006 - 01:17 PM
I have the same tank on the L.....If you get to reserve you have plenty of time to go and get more gas....If you want to drain every drop out of both sides just lean the bike over once and it will transfer.
  • Hot  186 replies
  • Hot  29 replies
  • Hot  35 replies
  • 9 replies
  • 3 replies
