Stripped Bolt Need Help!
6 replies to this topic
  • Alex_YZ450F
Posted August 23, 2006 - 03:37 AM
Hi,
I was changing the oil on my 450 and accidentally overtightened the right side lower crankcase drain bolt. In doing so I stripped a fair, 1/4'', amount of threads off of the inside (not the bolt). My question is; will I be ok with just putting on a new bolt, the flange on the current one is crooked, or should I get it re-tapped? The bolt is out of the bike and any help would be greatly appreciated.
Alex
  • CRFThumper
Posted August 23, 2006 - 03:43 AM
You may get lucky and be able to use a longer bolt if not it will need to be fixed. Maybe a helicoil would do the job for you,I would be very careful with this as it is a oil drain!
  • Alex_YZ450F
Posted August 23, 2006 - 06:33 AM
Thanks for the help.
  • mike_dean
Posted August 23, 2006 - 09:23 AM
The best fix would be a timesert which comes in a kit for the size you require, it will be permanent and will not strip out again, if you google timesert you should come up with their website and you can order direct. Mike
  • never59
Posted August 23, 2006 - 10:26 AM
Either of those will work fine alex. It is pretty scary to drill into a piece of magnesium, especially when you are dealing with oil but it is a really easy process to do. Take your time and you will be pleasantly suprised how easy it is to fix! good luck
Posted August 23, 2006 - 12:40 PM
"Lower right side" sounds like an '06. If so, I'd like to know:
What does magnesium have to do with it? (the crankcase is aluminum), and,
How do you propose to drill or tap into that hole? (the rear of the engine has to be raised far enough to get the drain hole out from behind the frame)
  • Alex_YZ450F
Posted August 23, 2006 - 02:08 PM
Yes it is an 06, and because of how cramped it is I am going to take out the engine.
  • 5 replies
  • 10 replies
  • Hot  36 replies
  • Hot  38 replies
