Trying to blaze new trails in the woods was easy til i got tired.Went down-Thought i bent the bars but when i got home the bars were good.The front tire is cocked alittle with the bars straight.I took it apart and cant seem to figure it out.Axle appears straight but wheel is still cocked.Any info will help.Thanks
hoping for an easy fix
Started by lewis23, Aug 22 2006 03:32 PM
12 replies to this topic
Posted 22 August 2006 - 03:32 PM
Posted 22 August 2006 - 03:40 PM
aaaauuhhh lets see. the only thing i can think of is the front forks have twisted a bit. ??
Posted 22 August 2006 - 04:04 PM
ya loosen the triple clamp, thats happened to my friends bike alot.
Posted 22 August 2006 - 04:44 PM
thanks ill try that after work I just rebuilt the motor but couldnt figure out the front wheel :bonk:
Posted 22 August 2006 - 06:20 PM
dont lossen anything. go find a tree or fence and bang the front wheel up against it (just like a bikecycle). after a few soft hits, itll be staright
Posted 22 August 2006 - 08:58 PM
bang it? hitting things never helps. Loosen you fork clamps, twist it straight, then retighten.
Posted 22 August 2006 - 09:21 PM
I agree works all the time! does that cause head shake?
Posted 12 November 2006 - 06:43 AM
you will shack your head alright, after you wreck something. these are not old XR's.
Posted 12 November 2006 - 07:09 AM
I realize this post is old, but I feel I need to reply. I have always straightend the front wheel with a tree. :ride: You didn't loosen anything to get it out of wack, so why would you need to loosen anything to straighten it? :excuseme: I have done this on my CRF before also. A couple smacks on the side of a tree will get you going and has no drawbacks that I've been able to tell in over 20 years of dirtbiking. I know it sounds barbaric, but it works. :thumbsup:
Posted 12 November 2006 - 08:47 AM
That works, but it is very hard on the fork seals, bushings and triple tree. Yes I know it wasn't loosened for you to move it in your crash, but if you want to do that mentallity why not try to crash it the other way to get them back? Also when you do that you get alum rubbed onto the forks under high pressure. This acts like grease kinda, and the next time you lay it down they will twist easier. Don't believe me, pull your fork tube out, I bet it has nasty black coating all over where it contacts the triple clamps.
Posted 12 November 2006 - 04:41 PM
Your probably right, but it's so much easier that I'm going to keep on doing it. :ride: It has never effected any of my bikes to the extent that I've noticed. :excuseme: My fork seals have always lasted their normal expectancy. I think it's safe to say that for the average rider, it won't cause any problems. I'll guess that I've done this probably a hundred times over the years. I definately wouldn't recommend for someone to try something that I thought would hurt their bike. So in conclusion, if you wipe out and twist your forks. If you want to take the time to go back to base and basically remove your front wheel, it will be better on your triple clamp and everything else. But if you want to pick it up and continue riding, then smack it against a tree and never look back. :thumbsup:
