I did a oil change yesterday and not much oil came out i drained both drain plugs on my rmz and not much oil came out i can still see oil in the oil glass thing on the clutch cover what did i do wrong??
Started by SEalpinestar05, Aug 22 2006 05:11 AM
7 replies to this topic
Posted 22 August 2006 - 05:11 AM
Posted 22 August 2006 - 06:58 AM
That doesn't make any sense?? You drained the oil, but you can still see oil in the sight glass?? Are you sure you took out the correct drain plug?
Posted 22 August 2006 - 09:10 AM
you probaly only drained the smaller of the plugs, the bigger bolt (14mm) holds the majority of the oil.
