Leaking valve stem
5 replies to this topic
  • FactoryHonda21
Posted 21 August 2006 - 02:09 PM
my back tire is always leaking from the valve stem, i tried a different tube, and nothing it still leaks. what can i doo to fix this?
  • smf919
Posted 21 August 2006 - 02:18 PM
put a cap on it? :excuseme:
  • Dan CRF250
Posted 21 August 2006 - 08:03 PM
it will still leak, try putting in a new valve in the tube
  • 723onYZ250f
Posted 21 August 2006 - 09:47 PM
just sounds like bad luck. try getting a different brand tube.
  • mxer255
Posted 21 August 2006 - 10:04 PM
It may not be the valve stem itself leaking but air coming out of the valve stem. Your rims can get metal spines after tire changes that can pop your tube from the inside or if your spokes are lose they can puncture a tire from the inside also. Take the tire off and look inside for anything that could be poping them and check your spokes as well. You have that rubber protector on the inside of your rim to keep the spokes away from your tube and I always wrap some duct tape or electrical tape around that to make sure they dont poke through.
  • FactoryHonda21
Posted 25 September 2006 - 09:53 AM
:applause: thanks guys great advice will try it out.
