YZ 426 Spewing Gas from Carb
5 replies to this topic
  • jdswanny
Posted August 21, 2006 - 10:00 AM
01- YZ426
In the last few months the carburator will spew gas out of the overflow hose? after you kick on it a few times and/or after you have ridden for a while and stop to rest. It will even do it if the engine is on while stopped in low rpm. Any suggestions.
  • socksahoy
Posted August 21, 2006 - 10:15 AM
The float is probably stuck, or there is some dirt or junk in the little needle valve assembly that the float opens and closes. I would take the carb off and pull the pin that the float pivits on, then blow out the place where the needle travels up and down with some compressed air.
  • jdswanny
Posted August 21, 2006 - 02:43 PM
Thanks for the reply. I tried and even replaced the needle valve set.
  • BergRyder
Posted August 22, 2006 - 08:22 PM
There is a rubber o ring inside the carb that will wear out and leak gas. The deterioration of the o ring is much faster with race gas. Replace the o ring and you should be ok. Happened to me a couple of weeks ago.
  • jbrooks26
Posted August 22, 2006 - 08:41 PM
You will also want to check the float height while you are in there. Hope this helps.
Josh
  • jdswanny
Posted August 23, 2006 - 01:59 PM
Thanks guys. Did the float height last night. Where is the O-Ring you are talking about????
  • Hot  38 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
