oil drain plug
8 replies to this topic
  • quailboy
Posted August 19, 2006 - 09:45 AM
so the idiot that owned my bike before me rounded the head off of my oil drain plug. how do i get it out or around it? and what do you recommend to replace it?
  • yogist
Posted August 19, 2006 - 10:20 AM
Grind a slot in it...Tap it loose with a screwdriver and a hammer...Buy a magnetic drain plug for your bike..To catch the small gear filings....Dont over tighten it..No need to go crazy on an oil drain plug..
  • kevin1209
Posted August 19, 2006 - 10:22 AM
I have had this happen twice to me. The first time I used a Dremel to flatten the head out on two sides so I could grab it with vise grips. The second time I drilled a hole in it and used an Easy Out bit to back it out. Any big auto parts store sells them.
Good luck. :thumbsup:
  • 99raptor
Posted August 19, 2006 - 11:26 AM
If you have enough of the :ride: bolt head I'd go with the vice grip method.Definetly get a :thumbsup: magnetic plug to relace the stocker.
  • barch88
Posted August 19, 2006 - 11:27 AM
Pretty much what I was going to say.
  • Crash 2006
Posted August 19, 2006 - 07:16 PM
If you can get a good set of vice grips in there (vice grip brand) that should do the trick. Try that first...
  • Dustin_Mabro
Posted August 22, 2006 - 05:07 AM
i had the same problem on my bike when i got it, i went to sears and bought a 5 piece set of these, they work great and they happened to be on sale when i needed em :thumbsup:
http://www.sears.com...UseBVCookie=Yes
  • xnofriendsx
Posted August 22, 2006 - 12:02 PM
I will second those Sears Bolt Out's.
I had a crazy stripped oil drain plug and the Sears Bolt Out just took it off like nothing.
Best $20 i ever spent.
Then go get a Zip Ty Racing Magnetic plug. Second best $20 you will spend.
  • Dustin_Mabro
Posted August 23, 2006 - 03:58 AM
:thumbsup: :ride: :applause:
  • 5 replies
  • Hot  30 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  47 replies
