05 YZ450 shock and fork settings
4 replies to this topic
  • DBMX 925
Posted August 17, 2006 - 02:27 PM
Can anyone tell me the factory fork and shock settings for an 05 YZ450, I've been through the manual 10 times and no info. Any help would be great. I bought the bike used and don't know the original settings. Thanks in advance.
  • 97chevy
Posted August 17, 2006 - 06:20 PM
I'm not trying to be a smart a** but, I am pretty sure it is in there. Look in the section inspections/adjustment which i think is chapter three. You will find a page about suspension and it will tell you mow many clicks of adjustment is there, and it should say the factory setting. Atleast this is how the 05 yz250f manual is. I'm thinking there is no reason the style of manual would be different, it would just have different specs. Hope it helps you out.
  • DBMX 925
Posted August 19, 2006 - 07:00 AM
Th :thumbsup: anks
  • Satch0922
Posted August 19, 2006 - 05:45 PM
Compression 8 clicks out
Rebound 13 clicks out
Rebound 12 clicks out
Low Speed Compression 13 clicks out
High Speed Compression 1 1/2 turns out
Sag...your preference but usually 100 +- 10mm
  • DBMX 925
Posted August 20, 2006 - 01:13 PM
Thanks again!
  • 9 replies
  • Hot  36 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  33 replies
