06 450 Carb Tips?
13 replies to this topic
  • x2stroker
Posted August 17, 2006 - 07:50 AM
Anyone know the easiest way to get to the top of the carb to service it? The aluminum fram encases the carb making it difficult to get to. Has anyone discovered an easy method. :thumbsup:
  • Budlite
Posted August 17, 2006 - 07:54 AM
Pull the seat and tank off.
  • Baron Von Beard
Posted August 17, 2006 - 08:14 AM
You have to remove the motor mounts. It's not that big of a deal. 5 bolts is all.
  • ben_suhard
Posted August 17, 2006 - 08:27 AM
Yep, that's the best way, but make sure that you are only loosening the bolts, not the nuts that are nicely embedded into the brackets like I tried to do!:thumbsup: I was wondering why they were so tight!
  • Baron Von Beard
Posted August 17, 2006 - 08:42 AM
Good point. I held those with a wrench the first time I pulled the mounts off until I realized they were pressed into the mount. :ride:
  • x2stroker
Posted August 17, 2006 - 08:44 AM
Thanks Guys! Now I'll know for the next time.
  • ben_suhard
Posted August 17, 2006 - 08:48 AM
I'm glad I'm not the only one, but I actually got mine to turn a bit too! :applause: :applause: :applause: I'm not totally dumb though, 'cause I only made that mistake once! :thumbsup:
  • NYMXer
Posted August 17, 2006 - 12:58 PM
Thanks guys...................I just learned something! :thumbsup:
  • FFRacing79
Posted August 17, 2006 - 06:57 PM
The top motor mounts do NOT need to come off to take the top carb cover off, say for a needle adjustment. Comes off just fine without even loosening the mounts. No need to make extra work. Tdub
  • SureBlue
Posted August 17, 2006 - 09:33 PM
True. And you need to remove the hot start and unplug the white TPS cable plug (not from the carb!)to be able to twist the carb enough for jet access.
  • DPW
Posted August 18, 2006 - 05:11 AM
I usually just remove the motor mounts in the carb area and loosen the front and rear clamp on the carb and that is it.
  • ben_suhard
Posted August 18, 2006 - 06:51 AM
Good point! You only need to take the brackets off for getting to the bottom of the carb.
Another good point, I forgot about that!
  • Baron Von Beard
Posted August 18, 2006 - 07:22 AM
No technically you don't have to pull the mounts to get at the needle, but I think it's easier than trying to fish everything around the mounts. For main and pilot changes, I pull the float bowl plug, loosen the clamps and turn the carb as much as possible and can get at the jets with a 1/4" ratchet and long socket for the main and a small flat head for the pilot.
  • SurvivorMan
Posted August 18, 2006 - 04:32 PM
To adjust or replace the needle, all that is neccessary is to take off the seat and tank and then loosen the clamps on both ends of the carb, give er a little twist and that is it.
I managed to move those nuts just slightly too....thats funny, I thought I was the only one!
  • Hot  47 replies
  • Hot  79 replies
  • Hot  36 replies
  • 5 replies
