Bigger WR450 Gas Tanks
30 replies to this topic
  • TooFast
Posted August 17, 2006 - 07:12 AM
I'm going to buy a larger capacity gas tank for my new 06 WR450, a little over 3 gallons, and wanted to hear the pros and cons from owners of the different tanks available. Tanks ahead of time. :thumbsup:
TooFast
  • jim-in-so-ore
Posted August 17, 2006 - 08:01 AM
I bought an IMS tank for my 03 WR450 a couple of years ago. I installed it and saw just how close the right hand petcock was to the header pipe and got chicken, took it back off and sent it back to whoever I got it from and got my money back. Later on I ordered a GYT R 3.4 gallon tank, installed it and saw that there was more clearance between the petcock and the pipe. I have never heard of anyone having a problem with the IMS tank and the lack of clearance, it just looked too close for comfort for me.
Jim
  • StreetbikePimp
Posted August 17, 2006 - 09:15 AM
My buddies bike has the IMS tank on his YZ450, and he did have some issues with the clearance between the petcock on the right side and the header pipe. Basically melted the rubber hose on him even though he took precautions to try to prevent that.
He ended up just plugging up the petcock on the right side of the tank and is only routing his fuel line from the left side of the tank. It's not a bad set-up that way. One way to look at it is that you have a 1/2 gallon reserve tank on the right side of your bike. :thumbsup:
  • Ripmeister
Posted August 17, 2006 - 09:58 AM
I put the Acerbis YZ tank on my WR and did what this guy says - had a friend machine a plug for the right side petcock. I like the YZ tank and seat set up better and it has worked out great for me.
http://www.motorcycl...&WT.MC_ID=80003
  • clark4131
Posted August 17, 2006 - 10:22 AM
Acerbis tank on my '05 with no clearance issues. I run both petcocks with an FMF PowerBomb header. The only thing I'd change is the supplied fuel line and "Y". Ditch them and get some 1/4" Tygon fuel line and a 5/16" brass automotive fuel "T"...SC
  • jim-in-so-ore
Posted August 17, 2006 - 11:43 AM
I agree with Clark on the fuel line and that crappy "y" fitting. I replaced the fuel line with clear and used a "T" also, but just not brass. I haven't had any problems.
Jim
  • Asgeir
Posted August 17, 2006 - 03:21 PM
I have a clear IMS tank and like it very much.
I had read all the posts here about how the Acerbis tank was better than the IMS but I found that the IMS suits me better.
The top is lower so you can sit more to the front of the bike.
The tank goes lower so when you want to race the bike the weight is lower.
I can not see this issue with the petcock to close to anything, all clearances in these bikes are tight anyway, or else they would weigh a ton.
ZipTy tanks are IMS.
GYTR tanks are Acerbis.
Look closly into this and make a decision that suits you.
  • FOZZ
Posted August 17, 2006 - 04:52 PM
Just got a Clarke tank for my 06 WR450 - Great people to talk with on the phone / had all the answers / they made me a black one & shipped it out the next day...
Fit just like stock - no mods - only complaint was the top finish was kinda rough looking..
  • johnnyjeep
Posted August 17, 2006 - 06:25 PM
I got the acerbis 6.6 and that puppy is HUGE. I only use it when Im going to need that much fuel. The weight is really something that you need to pay attention to.
I know you didnt ask about this big of a tank, but I threw in my $.02 in anyway.
John in Vegas
  • tigerowner_ut
Posted August 18, 2006 - 03:27 PM
Johnnyjeep. Did you get everything ironed out with your tank install?
I haven't heard if the guy who bought the 4.0 gallon Aqualine ever recieved it.
  • johnnyjeep
Posted August 18, 2006 - 04:18 PM
well kind of. I had to make a bracket to hold the seat down and had to grind a little off the support bracket around the radiator hose. the big issue is the weight of all that gas- its heavy!
http://i114.photobuc...ep/55c4399e.jpg
http://i114.photobuc...ep/60629002.jpg
http://i114.photobuc...ep/60712002.jpg
The last one shows the bracket I made
John in Vegas
  • Cicow
Posted April 21, 2009 - 06:50 AM
I made this:22 l Cagiva T4
more info
http://drcsapo.uw.hu...tank/index.html
:banghead:
i hope you like it.
  • IBLucky
Posted April 21, 2009 - 07:18 AM
I have an IMS 3.1 for my 07, and the pet cock is on the left side' it fit like the stock one and is low like the stock one, actually a nice tank! I stayed away from the Clark because of high it sticks up. but in saying that, i have never tried one. I just thoght it might be an issue with the way I ride.
  • qualityfishing
Posted April 21, 2009 - 08:15 AM
I got the 3.6 Acerbis for my 06 because I didnt like the header boiling fuel issues with the IMS. I have no issues with the acerbis
  • OUTERLIMITS
Posted April 21, 2009 - 09:20 AM
I did the same as you and really like that tank for the 07 and up. After I bought it, Clarke came out with their new tank for the 07 that does not require YZ shrouds and is a little bigger. Still, I think that while IMS may not go after the most capacity, in general they seem to go after as much capacity as they can while still keeping the fuel low and help facilitate rider movement. I will say though, that I have seen gas boil in an IMS tank for the earlier steel frame WR's. Not a very happy sight I must say.
  • redhurricane
Posted April 21, 2009 - 09:51 AM
I have the IMS tank in clear on my 2006 WR450
Perfect fit, left hand petcock only. No issues at all, in fact I got a replacement fuel cap seal (rubber insert) for free from IMS when the first one broke up on me from ham fisting it on too much.
No need for YZ shrouds or other monkey business, plenty of fuel for my style of riding, and as mentioned before lower CG than the Acerbis/Clarke tanks.
  • dirtrider999
Posted April 21, 2009 - 11:23 AM
i have the IMS 3.1 on my 2007 and i love it. and i use the stock wr shrouds. with a little bit of effort you can make the stock shrouds work.
  • P0ACHER
Posted April 21, 2009 - 12:13 PM
I had an IMS 3.1 on my '03 WR and it did boil the gas. Overall it was a very nice tank with better ergos for a more motocross forward riding style.
I've been on the fence about which way to go for my '08 WR. You can get an IMS in black now I believe. I've heard others say the Clarke is nice, but kinda rough finished. The 3.1 IMS to 3.3 Clarke is not enough extra capacity to sway me.
  • OUTERLIMITS
Posted April 21, 2009 - 02:05 PM
It's actually a 3.6 on the new Clarke. Design is similar to the IMS with a little more up top. Still, I have only seen people use the IMS tanks on the trail. Not that there is anything wrong with the Clarke, but kind of like restaurants, the ones with the best food usually have the most people in them. I know that many radiator guards fit the IMS, but would be worth double checking with Clarke for their tank. The pic does show a stabilizer so that should not be an issue.
http://www.clarkemfg...ode=Yamaha WR-F
  • 123BigcoopDawg576
Posted April 21, 2009 - 06:16 PM
its also 100 bucks cheaper than the ims :banghead:
