Top ten Genuine parts
8 replies to this topic
  • bluebike1999
Posted August 16, 2006 - 03:11 PM
i am currently looking at building some stock for local riding group and friends and wanted some input as to the most popular parts ordered.
I am going to get a store of head and base gaskets, and want to know what are the most common ordered genuine parts.
even if you cant think of ten, please list what you have purchased from your local Yam dealer.
please include year of bike
thank you for your help.
  • 642MX
Posted August 16, 2006 - 07:13 PM
Here is the most recent parts I've bought. 2002 YZ426F
All OEM parts, most purchased from online Yamaha stores.
Clutch basket
Clutch hub
Clutch thrust washer
Oil Filter cover O-rings
Mag cover gasket
Cam chain
sprocket bolts and nuts
Frame drain plug and washer
Spark Plug
Thats all I can think of. I just put the basket and hub in tonight. :thumbsup:
  • bluebike1999
Posted August 16, 2006 - 10:46 PM
thanks 642
stuff like the sproket bolts and nuts is a good one to have a few of.
i'm getting in a few seat bolts and chain slides too.
have cam chains for aus$68
will order the frame oil plug and washers too. handy to have.
  • Turismo
Posted August 16, 2006 - 10:56 PM
Yeah, the front sprocket lock washer too!
as well as jets, seat bolts, exhaust gaskets, fork seals.
I need frame oil drain bolt washer!
  • bluebike1999
Posted August 17, 2006 - 03:21 AM
one on the way
  • nurooi
Posted August 17, 2006 - 04:54 AM
Recently bought:
[1]. Oil;
[2]. Spark plug
[3]. Oil filter;
[4]. Coolant;
[5]. Various nuts and bolts;
[6]. Clamps for the hoses into and out of carburettor.
[7]. Tank bolts;
[8]. Decals
[9]. Chain lube;
[10]. Levers Set of clutch and brake as well as tyre tubes.
[11]. Various jets and fuel screw;
[12]. Exhaust packing.
Not in this order.
  • tp3dxf
Posted August 17, 2006 - 09:34 AM
How about clutch and throttle cables.
  • bg10459
Posted August 17, 2006 - 09:59 AM
Tubes and brake pads :thumbsup:
  • kskyles
Posted August 17, 2006 - 01:21 PM
05 WR450
impeller shaft, bearing, oil seal, water seal, and side case gasket!
