YZ400 Gearbox problem
3 replies to this topic
  • kimey46
Posted August 16, 2006 - 04:21 AM
Hi there, i currently own a 2000 yz400f and have a problem with the gearbox. 1st and 2nd gear are fine but when i try and select third it just grinds, when you go past third 4th gear seems to be fine. Just wondered if anyone else has had this problem.
thanks steve
  • rdefonce
Posted August 16, 2006 - 08:29 AM
No, never had that issue. Whatever it is, sounds like it needs a tearin' down to have a look. No doubt it will be obvious then!
You probably shouldn't ride it much, 'cause it could do more damage.
  • 02YZ426
Posted August 16, 2006 - 01:46 PM
You likley have a bent shift fork, and need to replace 3rd gear and the mating gear which is 4th I believe. Thats a bad deal, now you have to pull the motor and split the cases :thumbsup:
  • tom nolan
Posted August 16, 2006 - 06:27 PM
I had 3rd gear go out on mine and it took out several others as well. Also some of the shrapnel hit the crank and rod. I was able to blend out the damage with a sanding disc. When i ordered replacements, i noticed that the replacement gears were shot peened for strenght. I think they realized they have a problem with 3rd gear. If you can do the work yourself, the cost is not that bad. If you go to a shop, your screwed
  • Hot  30 replies
  • 10 replies
  • Hot  38 replies
  • Hot  47 replies
  • 5 replies
