06 YZ Cam's Intake mostly
5 replies to this topic
  • ISBB
Posted August 14, 2006 - 10:15 AM
I have seen that the 06 exhaust cam will fit in my 02 426 w/ the timing chain not fitting PERFECTLY ( which has been proven to not effect anything ) and the timing marks not lining up... Now is there any reason whatso ever i cannot use the intake cam as well? Will there be any bennifit w/ using the intake cam from a 06 yz? I am currently very stock and i need to replace the timing chain and a good buddy of mine just put Hotcams in his 06 yz and had his originals and said if i can use em to use em.. :thumbsup:
  • Turismo
Posted August 14, 2006 - 10:36 AM
I would throw in both and see how they go.
  • simon@vic
Posted August 15, 2006 - 08:09 AM
i think the intake cam is the same on the wr and yz.......... dont waste your $
  • Turismo
Posted August 15, 2006 - 08:32 AM
Different part numbers......
  • simon@vic
Posted August 15, 2006 - 01:30 PM
i think the intake cam is the same on the wr and yz.......... don't waste your $
more like,.............
i think the intake cam profile and position are the same on the wr and yz.
the dif in part #s could be because the yz cams have marking cuts on the gear faces. but I'm not sure.
if i where you i would find out for sure before you spend the $$.
  • ISBB
Posted August 15, 2006 - 01:48 PM
man you guys didnt even read my first post... ZIP ZERO NADA... they were hand me downs from a buddy that upgraded to hotcams and has no need for his stockers... I was thinking that the since the timing marks are diffrent that it would be a pain in the neck to get it timed properly without using some form of degree wheel to set them up properly.. ohh well.. ill jsut stick to the exhaust cam..
