Hot start lever stuck....
8 replies to this topic
  • DRZBigB
Posted August 14, 2006 - 08:00 AM
My Brothers '03 WR450F's Hot Start lever is stuck open... Is there a quick fix for this, or is there a lot of disassembly required..
Bike runs fine, but I'm sure that it can't be good for it..
Ideas?
Thanks
  • SJMC_DON
Posted August 14, 2006 - 08:15 AM
You can take it off but be careful of the plastic coupler they can be a pain in the a$$..... It may be a fusty cable too.
  • 450pmp
Posted August 14, 2006 - 10:14 AM
If it's the same as the 04, you just back the plunger out of the carb and lube it up and re-install. I lube my hot start plunger a couple times a year cause it does get sticky! :thumbsup:
  • SJMC_DON
Posted August 14, 2006 - 11:03 AM
The cables tend to get water in them from pressure washing, mine will freeze in the winter time when I drive over the mountains, the bars stick out above the cab of my truck and by time I get to eastern washington that Hot Start cable is frozen :thumbsup:
  • Oldsmobiler
Posted August 14, 2006 - 02:07 PM
Its a piece of cake to take off but I HIGHLY recommend that you change the piece of crap plastic hot start carb nut with one of these http://www.ziptyraci...spx?id=MTI5Nw==. Mine was stripped from the dealership monkeys so they gave me one off a new bike. It was already starting to show signs of losing threads :thumbsup: . I betcha that the plunger is siezed in the bore. Take it apart and lube it up with a dab of lithium grease.
Ante
  • odonnks
Posted August 14, 2006 - 06:07 PM
Chief.... you'll be real lean.
  • DRZBigB
Posted August 14, 2006 - 10:10 PM
Lean - that makes perfect sense why he was popping, and sputtering soo much...
I'll tell him, and maybe we can tear into it...
Thanks...
PS: Any Diagrams?
  • DRZBigB
Posted November 07, 2006 - 07:11 PM
Done.... Easily fixed - a little WD40 and it unfroze - runs like a top now!
  • shotgunscott
Posted November 07, 2006 - 07:52 PM
http://www.hotstartsystem.com/
Have not had a stuck hot start since I have been using this system.:mad:
