03 wr 450 stalling
7 replies to this topic
  • bigblockchevelle
Posted August 14, 2006 - 03:44 AM
Hey guys, twice now i have been cruising down a backroad (gravel) at about 60 and the bike just dies like someone turned a key off. Coast to a stop and have to choke it to get it to start but it fires right up. Is there a common electrical connection or something to look for. it is so intermittent that im not sure where to start?
  • gregwr450f
Posted August 14, 2006 - 04:16 AM
check to see if any wires are being crushed by the steering stops.
  • Christi20
Posted August 14, 2006 - 07:50 AM
Also check wiring in and around airbox, seat area. Some of the wires may rub on the subframe and contact metal and short out.
  • 450pmp
Posted August 14, 2006 - 10:16 AM
Check your fuel cap vent too!
  • bigblockchevelle
Posted August 15, 2006 - 03:47 AM
I am going to check all these things tonight. I had wondered about that fuel tank vent as it sometimes gets twisted. Would that cause the bike to completely die out like that?
  • Turismo
Posted August 15, 2006 - 04:34 AM
Sounds like classic blocked fuel vent. Blocked vent causes vapor lock, kills the bike then carby slowly fills back up.
  • bigblockchevelle
Posted August 15, 2006 - 09:04 AM
Its amazing how something so simple can evade you until someone else reminds you of the obvious. Thanks guys, i'm guessing thats what it was as i have noticed that it was twisted a couple times.
Now on to changing the seals on the water pump shaft!!
  • ckulzer
Posted August 15, 2006 - 10:36 AM
I have had this happen twice. Dry conditions and it did not seem to be fuel related. Motor just up and quit running. Started back up straight away too....
Weird.
