Why is my YZ400F is idling too high?
7 replies to this topic
  • rdefonce
Posted August 12, 2006 - 02:53 PM
I just removed the carb, cleaned parts, and re-assembled.
All settings were as before carb removal. Throttle has play, I tried to fully back-off the idle adjustment. Got any ideas, thanks!
  • barch88
Posted August 12, 2006 - 03:57 PM
What RPM is it running at?
  • jamieyz426f01
Posted August 12, 2006 - 04:05 PM
your hotstart isn't sticking out?
  • rdefonce
Posted August 12, 2006 - 05:16 PM
I'd have to guess it's idling at 3000 rpm, and no the hot-start is not sticking out. (Choke's not out either.)
  • jimbob69
Posted August 12, 2006 - 06:24 PM
Cracked/spliced hotstart hose, dryrotted carb boot, loose carb clamps, and possibly loss of the small little oring on the fuel screw can all play a role in that.
  • rdefonce
Posted August 13, 2006 - 07:25 AM
Jimbob69, thanks for tips. My old YZ has led a charmed life since new: climate controlled garage, low hours for a '99. (And this is how it repays me! I know, it's probably something I did but it's easy to pass the buck ain't it.) All the rubber parts are like new still, clamps tight, didn't mess with fuel screw. I will triple-check those things again though.
It's a really even high-idle; seems as though the slide is being physically held open. (Doesn't have a lean/uneven sound to it.) Could the needle be touching the main jet somehow? or possibly the metal-plate thing on the slide not be on just right and interfering somewhere?
I will have to dig in.
  • FriscoKLR
Posted August 13, 2006 - 07:49 AM
Make sure your rebound throttle cable isn't freighed and hanging up inside the cable guide just up from the carb.
  • rdefonce
Posted August 13, 2006 - 10:33 AM
Throttle cable was just a tad frayed, so I replaced that.
I discovered the problem: I installed the plate that "nests" in the slide upside down. :ride:
It's really easy to do; it even looks correctly installed when it's upside down. MY BAD!
Getting the slide out is somewhat of a puzzle, so now I'm getting better at it . . . should be good to go now, and thanks for all your tips. :thumbsup:
  • Hot  36 replies
  • Hot  113 replies
  • Hot  47 replies
