desert riding
5 replies to this topic
  • govana72
Posted August 10, 2006 - 12:49 AM
i run a 14t front and a50t rear. what should i run for top end for a 2000 wr 400
  • taksx
Posted August 10, 2006 - 07:35 AM
On a 05 WR450 stock is 14/50, but I use 15/50 for high speed stuff (baja,flat dez,dunes) works good try it
Eddie :thumbsup:
  • SJMC_DON
Posted August 10, 2006 - 08:33 AM
Eddie :thumbsup:
Ditto - You may have to "tool out" your case saver a little to run the 15T C/S sprocket though. I did on my 04'.
  • jonova
Posted August 11, 2006 - 07:19 AM
I run a 14/45 on my 01 WZ 444 and top out at 100mph. It won't win baja but it gets me by down there on long mexican roads. I run the same gearing in the woods too. I just stay in first and chug it along.
A 14/45 will have a bit taller top speed than a 15/50.
  • Koko Azuela
Posted August 12, 2006 - 12:57 PM
I run a 15/46, runs great in baja, im thinking on getting a 44 for the rear and see how faster it gets, with the 15/46, it tops out around 94MPH!!!
  • Ibis
Posted August 14, 2006 - 11:45 AM
I agree. I use 15/47 for Baja, but am also considering a 44 for the times we have to do some highway cruising. BTW, a WR's 5th gear with 15/44 is very close to a KTM 450 EXC's 6th gear with stock gearing.
If I were doing 100% desert with no lower RPM cruising, I think I would try the 15/50. It's the simplist thing to do and besides, I don't think the WR has the HP to spin a much higher gear than that for top speed.
