rich or lean?
2 replies to this topic
  • codyblanchard
Posted August 09, 2006 - 08:02 PM
How do you tell if a bog is a rich or lean one? I did the bk mod on a '00 426 but it still bogs badly. I went smaller on the pilot because I couldn't make it die when turning the screw all the way in. It idles pretty good at about 2-2.5 turns out. Just wondering which direction to go.
  • WFOracer
Posted August 10, 2006 - 05:10 AM
Use this for testing the pilot circuit.....you may have to turn your idle up as well. Do you have an easy adjust pilot (fuel) screw? If not, get one. It male tuning your carb much easier.
http://www.thumperta...ad.php?t=327405
  • george maybroda
Posted August 10, 2006 - 08:04 AM
normally a bogg is a lean condition. i would use the old pilot do the test correctly and go from there. a quicker way to test rich/lean cindition is tape the air box and see if it helps or gets worse. tape off maybe half of the air box but not all. if it feals better than you are lean. if it gets worse you are rich.
Motocross
  • Hot  491 replies
  • Hot  47 replies
