Side Case Cover/Guard
8 replies to this topic
  • TARFELE
Posted August 09, 2006 - 02:49 AM
I know CNC makes makes side case protectors but I cannot find one for the 650L. Any ideas where to look.
And yes, I already did a search with only three results
Thanks
  • HappyCurmudgeon
Posted August 09, 2006 - 03:27 AM
Not sure if this is what you meant, but try Here
  • TARFELE
Posted August 09, 2006 - 05:55 AM
No, not exactly. CNC makes a flat disk that you place on the side case/clutch cover and it protects it from the brake or shifter from cracking the magnesium cover. I have one on my WR but I cannot find one for the 650L. I guess I should call it a case shield. The Thumpertalk store sales one for the DRZ
  • BajaBoundMoto
Posted August 09, 2006 - 06:26 AM
Have you had the brake or shifter push thru the covers? Aftermarket guards aren't made for the 600/650L because the clutch/ignition covers on those bikes are very strong, not wimpy like most bikes nowdays.
  • TARFELE
Posted August 09, 2006 - 07:47 AM
I disagree the magnesium is very weak. I had my side case crack in Mexico after the bike fell over and the shifter put a small crack in the side case. It was very small but it still leaked. I fixed it with Moose Putty. A friend actually had a gaping hole in his after he wrecked and the case was cracked by a rock. He lost all of his oil.
I think I may try and make my own.
  • motomonte
Posted August 09, 2006 - 09:46 AM
Check out some post from a few weeks ago by justicedone and myself where we discussed this same problem.I even gave some ideas & measurements if you wanted to fabricate one yourselves.Believe me they work,this i learned after cracking the cases twice.
  • rmhrc630
Posted August 09, 2006 - 12:06 PM
The engine side covers on the 650L are not mag.
They're either light alloy or steel
  • motomonte
Posted August 10, 2006 - 02:40 AM
They are some kind of aluminum alloy.Welds up really good.l
  • TARFELE
Posted August 10, 2006 - 04:01 AM
Okay, your right, :thumbsup: but that did not help me find a cover yet. :ride:
