IS My BD DSK Regulator Toasted?
2 replies to this topic
  • jamestoo
Posted August 08, 2006 - 02:30 PM
Having just rewound my stator I am only getting 4 volts output from the regulator (Measured at the charge side that connects to the little battery) whereas there are 17 volts + now coming out of my Stator the battery will only hold the 55w headlamp bulb for less than 2 minutes
I presume i've fried the regulator! :thumbsup:
Am I correct in this thought?
  • jamestoo
Posted August 09, 2006 - 05:11 AM
Is it safe to just bypass the regulator?
  • 4Takt
Posted August 09, 2006 - 06:14 AM
Is there a load hooked up the the stator output?
I had a similar problem, 4+ V DC, turns out I had a partial short to ground in the handle bar switch unit that was dragging down the voltage.
I was also dumb enough not to use a fuse, so the regulator got very hot trying to deliver enough current.
Once I unplugged the switch unit the voltage jumped back up to where it should be, and I was able to trace down the short and fix it.
Using a fuse now btw, after realizing I could have set my bike on fire.
So anyway, try disconnecting everything and just measure the rectifier/regulator output to ground.
4Takt
Honda XR650L 2017
  • 0 reviews
  • 4 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
